Poly Voyager Focus 2 UC-M USB-A with Stand
Quicklinx: HLM5WS00 Mfr#: 77Y87AA
Recommended Use: Portable electronics, Computer
Connectivity: Wireless, Wired
Earcover : Binaural
£162.80 ex VAT
£195.36 inc VAT
Create a focus zone around you with the Voyager Focus 2, stereo Bluetooth headset. Smartly engineered for audio perfection – all you will hear is your call. And the focus stays on you, right where it belongs.
  • Immersive experience
    Stay focused while on calls or listening to music/media with stereo sound.
  • Easy to use
    An easy-to-use headset with smart sensors for answering/muting calls and playing/pausing music. The intelligent microphone boom automatically maintains left and right audio no matter which side the headset is worn on.
  • No need for battery anxiety
    Keep your headset fully charged using the included desktop charging stand. You can also extend the battery life by using it corded, with audio over USB mode.
  • Choose your device
    Works with your choice of device: PC via included BT700 USB-A or USB Type-C ? Bluetooth adapter and mobile phones via Bluetooth v5.1.
  • Smart Sensors
    Dynamic Mute Alert senses and tells you when talking while muted. And the on-ear indicator light flashes to let others around you know you are on a call to keep you distraction free.
  • Certified for Microsoft Teams
    Full Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more.
Poly Voyager Focus 2-M - headset - USB-A via Bluetooth adapter
Headset - Bluetooth - wireless, wired - USB-A via Bluetooth adapter
Recommended Use
Portable electronics, computer
Headphones Form Factor
On-ear
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Active Noise Canceling
Microphone
Boom
Microphone Operation Mode
MEMS-directional
Microphones Included
4
Controls
Mute, volume, power on/off, answer/end, ANC mode
Software Certification
15.5 cm
6.7 cm
18.2 cm
176 g
Earpad Material
Artificial leather
Recommended Use
Max Operating Distance
50 m
Audio Output
On-ear
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Stereo
Active Noise Cancelling Technology
Hybrid Active Noise Cancelling
Frequency Response
20 - 20000 Hz
Diaphragm
32 mm
Adjustable Headband
Simultaneously Connectable Devices Qty
2
Dynamic EQ optimised
Microphone
Boom
MEMS-directional
4
Frequency Response
100 - 6800 Hz
Remote Control
Controls
Connector Type
USB (USB Type-A)
Charging cable, BT700 Bluetooth USB adapter, travel pouch, charging stand
Cable Details
Micro-USB charging cable
Supported Host Device OS
Windows 11, Windows 10, macOS
Headset battery rechargeable - Lithium Ion
560 mAh
Run Time (Up To)
40 hours
Run Time Details
Continuous talk (noise cancelling ON): up to 16 hours , Continuous talk (noise cancelling OFF): up to 18 hours , Continuous hearing (noise cancelling ON): up to 24 hours , Continuous hearing (noise cancelling OFF): up to 40 hours
Standby Time
30 days
Recharge Time
2 hours
Shipping Width
21 cm
Shipping Depth
19 cm
Shipping Height
11.5 cm
Shipping Weight
712 g
HLM5 Poly Spare BT700 Bluetooth USB Adapter In Stock £59.35
HLM5 Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager In Stock £87.61
HLM5 Poly - USB adapter - USB to 24 pin USB-C In Stock £12.86
HLM5 Poly - USB adapter - 24 pin USB-C to USB In Stock £12.95
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
Brand: Poly
