Create a focus zone around you with the Voyager Focus 2, stereo Bluetooth headset. Smartly engineered for audio perfection – all you will hear is your call. And the focus stays on you, right where it belongs.
Immersive experience
Stay focused while on calls or listening to music/media with stereo sound. -
Easy to use
An easy-to-use headset with smart sensors for answering/muting calls and playing/pausing music. The intelligent microphone boom automatically maintains left and right audio no matter which side the headset is worn on. -
It's your call
Stay productive with up to 19 hours of wireless talk time (ANC on) and extend the battery life by using it corded, with audio over USB mode. -
Choose your device
Works with your choice of device: PC via included BT700 USB Type-C ? Bluetooth dongle and mobile phones via Bluetooth . -
Connectivity options
Enhanced connectivity for your devices with a USB Type-C ? charging cord and tethered USB-A adapter. -
Smart sensors
Dynamic Mute Alert senses and tells you when talking while muted. And the on-ear indicator light flashes to let others around you know you are on a call to keep you distraction free.
- Poly Voyager Focus 2 - headset - USB-C via Bluetooth adapter
- Product Type
- Headset - Bluetooth - wireless - USB-C via Bluetooth adapter
- Recommended Use
- Phone, computer
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Stereo
- Active Noise Canceling
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional x 4
- Microphones Included
- 6
- Controls
- Mute, volume, power on/off, answer/end, ANC mode
- Intelligent Assistant
- Siri, Google Assistant
- Environmental Standards
- TCO Certified Headsets 9
- Software Certification
- Zoom Certified
- 2-year warranty
- Product Type
- 15.5 cm
- 6.6 cm
- 18.3 cm
- 175 g
- Black
- Recommended Use
- Phone, computer
- Max Operating Distance
- 50 m
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Active Noise Cancelling Technology
- Hybrid Active Noise Cancelling
- Diaphragm
- 32 mm
- Simultaneously Connectable Devices Qty
- 8
- SoundGuard DIGITAL Technology, Smart Sensor Technology, Acoustic Fence technology, dynamic mute alert
Microphone
- Boom
- 6
- Frequency Response
- 100 - 6800 Hz
Remote Control
- Controls
- Connector Type
- Wireless adapter (USB Type-C)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Software Included
- Poly Lens
- Included Accessories
- Carrying pouch, charging stand, USB-C charging cable, USB-C to USB-A adapter, BT700 Bluetooth USB-C adapter
- Supported Host Device OS
- Windows 10, macOS, Windows 11
- Zoom Certified
Sustainability Information
- TCO Certified
- Battery
- Headset battery rechargeable - Lithium Ion
- Run Time (Up To)
- 40 hours
- Run Time Details
- Continuous talk (noise cancelling ON): up to 16 hours , Continuous talk (noise cancelling OFF): up to 25 hours , Continuous hearing (noise cancelling ON): up to 24 hours , Continuous hearing (noise cancelling OFF): up to 40 hours
- Recharge Time
- 2 hours
- Limited warranty - 2 years
- Shipping Width
- 19 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 382 g
Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager | In Stock | £89.69 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £13.36 |
