Here's a Bluetooth neckband headset with earbuds that's as professional and versatile as you. With Voyager 6200 UC, wear just one earbud for voice calls and both earbuds for music. Stereo sound and active noise cancelling (ANC) help you focus-while you stay productive and connected.
All day comfort
Designed to be comfortable and low profile, you can wear this neckband headset all day long, in and out of the office. And with the comfort-fit earbuds you'll forget you're wearing it at all. -
As verstile as you
Work more flexibly-switch from stereo to mono by dropping an earbud, or remove both earbuds for face-to-face conversations. -
Stay focused
Block out distractions and remain focused on calls or work with on-demand passive and active noise cancelling (ANC). In-ear design provides passive noise reduction with earbuds in three sizes for a snug fit that blocks sounds. -
Premium audio experience
Immerse yourself in your favorite music and podcasts using premium hi-fi stereo. And enjoy superb sound with wideband audio for high-quality PC telephony, compatible with smartphones enabled for HD voice. -
Stop guessing if you are on mute
Eliminate mute anxiety. The dedicated mute button and visual mute indicator help remove unnecessary stress on calls. Dynamic Mute alerts and voice prompts alert users when they try to talk and the sound is off. -
Enhanced alerts
Stay accessible and available with enhanced voice alerts and a vibrating neckband that announce caller ID, mute and connection status and remaining talk-time. Vibrating neckband signals incoming calls and alerts.
- Poly Voyager 6200 - headset
- Product Type
- Headset - Bluetooth - wireless, wired - USB-A
- Recommended Use
- Computer
- Additional Functions
- DSP
- Black
- Headphones Form Factor
- Ear-bud - over-the-ear mount
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Microphone Operation Mode
- Omni-directional
- Microphones Included
- 4
- Controls
- Volume, mute button, answer/end, play/pause, next/previous track
- Software Certification
- Certified for Microsoft Teams
- Product Type
- DSP
- 19 cm
- 18 cm
- 7.6 cm
- 56 g
- Black
- Recommended Use
- Computer
- Voice alerts
- Max Operating Distance
- 30 m
Audio Output
- Wireless, wired
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Diaphragm
- 14.6 mm
- Simultaneously Connectable Devices Qty
- 8
Microphone
- Form Factor
- Built-in
- Omni-directional
- 4
Remote Control
- Controls
- Connector Type
- USB (USB Type-A)
- Included Accessories
- Carrying case, 3 pairs of ear tips (small, medium, large), charging stand, BT700 Bluetooth USB adapter
- Battery
- Headset battery rechargeable - lithium polymer
- Run Time (Up To)
- 16 hours
- Run Time Details
- Continuous playback: up to 16 hours , Continuous talk: up to 9 hours
- Standby Time
- 336 hours
- Shipping Width
- 21 cm
- Shipping Depth
- 19.2 cm
- Shipping Height
- 5.7 cm
