Poly Voyager 6200UC B6200 Black WW
Quicklinx: HM5PWS00 Mfr#: 7D7G5AA
Recommended Use: Computer
Connectivity: Wired, Wireless
£160.98 ex VAT
£193.17 inc VAT
Here's a Bluetooth neckband headset with earbuds that's as professional and versatile as you. With Voyager 6200 UC, wear just one earbud for voice calls and both earbuds for music. Stereo sound and active noise cancelling (ANC) help you focus-while you stay productive and connected.
  • All day comfort
    Designed to be comfortable and low profile, you can wear this neckband headset all day long, in and out of the office. And with the comfort-fit earbuds you'll forget you're wearing it at all.
  • As verstile as you
    Work more flexibly-switch from stereo to mono by dropping an earbud, or remove both earbuds for face-to-face conversations.
  • Stay focused
    Block out distractions and remain focused on calls or work with on-demand passive and active noise cancelling (ANC). In-ear design provides passive noise reduction with earbuds in three sizes for a snug fit that blocks sounds.
  • Premium audio experience
    Immerse yourself in your favorite music and podcasts using premium hi-fi stereo. And enjoy superb sound with wideband audio for high-quality PC telephony, compatible with smartphones enabled for HD voice.
  • Stop guessing if you are on mute
    Eliminate mute anxiety. The dedicated mute button and visual mute indicator help remove unnecessary stress on calls. Dynamic Mute alerts and voice prompts alert users when they try to talk and the sound is off.
  • Enhanced alerts
    Stay accessible and available with enhanced voice alerts and a vibrating neckband that announce caller ID, mute and connection status and remaining talk-time. Vibrating neckband signals incoming calls and alerts.
Poly Voyager 6200 - headset
Headset - Bluetooth - wireless, wired - USB-A
Recommended Use
Computer
Additional Functions
DSP
Headphones Form Factor
Ear-bud - over-the-ear mount
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Microphone Operation Mode
Omni-directional
Microphones Included
4
Controls
Volume, mute button, answer/end, play/pause, next/previous track
Software Certification
Certified for Microsoft Teams
DSP
19 cm
18 cm
7.6 cm
56 g
Recommended Use
Computer
Voice alerts
Max Operating Distance
30 m
Audio Output
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Diaphragm
14.6 mm
Simultaneously Connectable Devices Qty
8
Microphone
Built-in
Omni-directional
4
Remote Control
Controls
Connector Type
USB (USB Type-A)
Carrying case, 3 pairs of ear tips (small, medium, large), charging stand, BT700 Bluetooth USB adapter
Headset battery rechargeable - lithium polymer
Run Time (Up To)
16 hours
Run Time Details
Continuous playback: up to 16 hours , Continuous talk: up to 9 hours
Standby Time
336 hours
Shipping Width
21 cm
Shipping Depth
19.2 cm
Shipping Height
5.7 cm
Connectivity: Wired
Connectivity: Wireless
Brand: Poly
