Poly Voyager 5200 UC B5200 Headset with Case
Quicklinx: HM57WS00 Mfr#: 7K2E1AA
Recommended Use: Portable electronics, Computer
Connectivity: Wired, Wireless
Earcover : Monaural
£93.27 ex VAT
£111.92 inc VAT
Working in and out of the office? We've got you covered. The Voyager 5200 headset provides professional-grade sound, no matter where you take the call. Now you can thrive in any environment on any of your devices, with versatile connectivity and Bluetooth technology.
  • Four-mic noise cancelling
    Cutting edge noise cancelling technology eliminates background noise, so your voice always sounds clear. Four-mic array and our adaptive Digital Signal Processors (DSP) work together to cancel disruptive background noise like traffic or crowds.
  • Take the call anywhere
    Six layers of our unique WindSmart technology detect wind direction and respond accordingly so your voice comes through clearly – especially outdoors.
  • High-quality audio
    Supports HD Voice over wideband networks and devices to enhance speech quality, so your caller clearly hears and understands you.
  • Smart sensor technology
    Smart sensors know when the headset is on or off; calls can be easily answered by simply putting on the headset; pause music for incoming calls, or mute a call by taking the headset off.
  • Manage your calls using voice commands
    Announces the names of incoming callers and waits for you to say "Answer" or "Ignore", allowing you to manage your calls using voice commands.
Poly Voyager 5200 UC - headset - USB-A via Bluetooth adapter
Headset - Bluetooth - wireless, wired - USB-A via Bluetooth adapter
Recommended Use
Portable electronics, computer
Headphones Form Factor
In-ear monaural
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Audio Specifications
Frequency Response 100 - 20000 Hz - Sensitivity 90 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Omni-directional, MEMS-directional
Microphone Noise Cancelling
Controls
Mute, volume control, on/off
Intelligent Assistant
Siri, Google Assistant
Software Certification
Certified for Microsoft Teams
9.1 cm
5.3 cm
1.5 cm
20 g
Earpad Material
Artificial leather
Recommended Use
Voice alerts, 280° rotatable microphone
Max Operating Distance
30 m
Audio Output
In-ear monaural
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Equaliser
20 bands
Frequency Response
100 - 20000 Hz
Sensitivity
90 dB
Impedance
32 Ohm
Diaphragm
13.6 mm
Digital signal processing, Smart Sensor Technology, echo cancelation
Microphone
Boom
Sensitivity
-38 dBV/Pascal
Frequency Response
100 - 6800 Hz
Noise Cancelling
Remote Control
Controls
Internet of Things (IoT)
3 ear tips (small, medium, large), charging case, micro-USB charging cable, Bluetooth dongle
Headset battery rechargeable - lithium polymer
122 mAh
Run Time (Up To)
7 hours
Standby Time
9 days
Recharge Time
1.6 hours
HM57 Poly Spare BT700 Bluetooth USB Adapter In Stock £58.49
HM57 Poly - USB adapter - USB to 24 pin USB-C In Stock £13.11
HM57 Poly - USB adapter - 24 pin USB-C to USB In Stock £12.95
Recommended Use: Computer
Connectivity: Wired
Connectivity: Wireless
Earcover : Monaural
Brand: Poly
