Working in and out of the office? We've got you covered. The Voyager 5200 headset provides professional-grade sound, no matter where you take the call. Now you can thrive in any environment on any of your devices, with versatile connectivity and Bluetooth technology.
Four-mic noise cancelling
Cutting edge noise cancelling technology eliminates background noise, so your voice always sounds clear. Four-mic array and our adaptive Digital Signal Processors (DSP) work together to cancel disruptive background noise like traffic or crowds. -
Take the call anywhere
Six layers of our unique WindSmart technology detect wind direction and respond accordingly so your voice comes through clearly – especially outdoors. -
High-quality audio
Supports HD Voice over wideband networks and devices to enhance speech quality, so your caller clearly hears and understands you. -
Smart sensor technology
Smart sensors know when the headset is on or off; calls can be easily answered by simply putting on the headset; pause music for incoming calls, or mute a call by taking the headset off. -
Manage your calls using voice commands
Announces the names of incoming callers and waits for you to say "Answer" or "Ignore", allowing you to manage your calls using voice commands.
- Poly Voyager 5200 UC - headset
- Product Type
- Headset - Bluetooth - wireless, wired - USB-A via Bluetooth adapter
- Recommended Use
- Portable electronics, computer
- Black
- Headphones Form Factor
- In-ear monaural
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Audio Specifications
- Frequency Response 100 - 20000 Hz - Sensitivity 90 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional, MEMS-directional
- Microphone Noise Cancelling
- Controls
- Mute, volume control, on/off
- Intelligent Assistant
- Siri, Google Assistant
- Software Certification
- Certified for Microsoft Teams
- Product Type
- 9.1 cm
- 5.3 cm
- 1.5 cm
- 20 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- Voice alerts, 280° rotatable microphone
- Max Operating Distance
- 30 m
Audio Output
- In-ear monaural
- Wireless, wired
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Equaliser
- 20 bands
- 100 - 20000 Hz
- Sensitivity
- 90 dB
- Impedance
- 32 Ohm
- Diaphragm
- 13.6 mm
- Digital signal processing, Smart Sensor Technology, echo cancelation
Microphone
- Boom
- Sensitivity
- -38 dBV/Pascal
- 100 - 6800 Hz
- Noise Cancelling
Remote Control
- Controls
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
- 3 ear tips (small, medium, large), charging case, micro-USB charging cable, Bluetooth dongle
- Battery
- Headset battery rechargeable - lithium polymer
- Capacity
- 122 mAh
- Run Time (Up To)
- 7 hours
- Standby Time
- 9 days
- Recharge Time
- 1.6 hours
Poly Spare BT700 Bluetooth USB Adapter | In Stock | £58.46 |
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £12.86 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HM57 050968 Condition: Customer return - item has been repaired under warranty by the manufacturer |
£60.79 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
