Poly Voyager 5200 Headset (no case)
Quicklinx: HM5LWS00 Mfr#: 80S12AA
Recommended Use: Computer, Portable electronics
Connectivity: Wireless
Earcover : Monaural
10 In Stock
£109.23 ex VAT
£131.07 inc VAT
Working in and out of the office? We've got you covered. The Voyager 5200 headset provides professional-grade sound, no matter where you take the call. Now you can thrive in any environment on any of your devices, with versatile connectivity and Bluetooth technology.
  • Four-mic noise cancelling
    Cutting edge noise cancelling technology eliminates background noise, so your voice always sounds clear. Four-mic array and our adaptive Digital Signal Processors (DSP) work together to cancel disruptive background noise like traffic or crowds.
  • Take the call anywhere
    Six layers of our unique WindSmart technology detect wind direction and respond accordingly so your voice comes through clearly – especially outdoors.
  • High-quality audio
    Supports HD Voice over wideband networks and devices to enhance speech quality, so your caller clearly hears and understands you.
  • Smart sensor technology
    Smart sensors know when the headset is on or off; calls can be easily answered by simply putting on the headset; pause music for incoming calls, or mute a call by taking the headset off.
  • Manage your calls using voice commands
    Announces the names of incoming callers and waits for you to say "Answer" or "Ignore", allowing you to manage your calls using voice commands.
Poly Voyager 5200 - headset
Headset - Bluetooth - wireless - USB-A via Bluetooth adapter
Compatibility
Windows, Mac
Recommended Use
Portable electronics, computer
Additional Functions
DSP
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Audio Specifications
Frequency Response 100 - 20000 Hz - Sensitivity 90 dB
Impedance
32 Ohm
Active Noise Canceling
Microphone
Boom
Microphone Operation Mode
Omni-directional, MEMS-directional
Microphone Noise Cancelling
Controls
Mute, volume control, on/off
Intelligent Assistant
Siri, Google Assistant
Software Certification
Certified for Skype for Business, Certified for Microsoft Teams, Zoom Certified, Cisco Jabber Certified, Avaya Certified, Works With Chromebook Certified
Series
Voyager 5200 series
Compatibility
Windows, Mac
DSP
9.1 cm
5.3 cm
1.5 cm
20 g
Earpad Material
Artificial leather
Recommended Use
Voice alerts, 280° rotatable microphone
Protection
Sweat-proof
Max Operating Distance
30 m
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Equaliser
20 bands
Active Noise Cancelling Technology
Frequency Response
100 - 20000 Hz
Sensitivity
90 dB
Impedance
32 Ohm
Diaphragm
13.6 mm
Digital signal processing, Smart Sensor Technology, echo cancelation, sidetone detection, SoundGuard Technology
Microphone
Boom
Sensitivity
-38 dBV/Pascal
Frequency Response
100 - 6800 Hz
Noise Cancelling
Remote Control
Controls
Internet of Things (IoT)
Software Included
Poly Lens
3 ear tips (small, medium, large), micro-USB charging cable, USB-A to microUSB cable
Cable Details
Micro-USB to USB-A cable - detachable
Supported Host Device OS
Windows, macOS
Headset battery rechargeable - lithium polymer
122 mAh
Run Time (Up To)
7 hours
Standby Time
9 days
Recharge Time
1.6 hours
HM5L Poly Spare BT700 Bluetooth USB Adapter In Stock £58.58
HM5L Poly - USB adapter - USB to 24 pin USB-C In Stock £12.86
HM5L Poly - USB adapter - 24 pin USB-C to USB In Stock £12.82
Recommended Use: Portable electronics
Earcover : Monaural
Brand: Poly
