Free yourself from your desk with the perfect affordable Bluetooth wireless single-ear (mono) headset. Meet the Voyager 4310 UC. It's everything you need to stay connected to all your devices whether at home or in the office. Keep yourself productive with all day comfort and dual-mic Acoustic Fence technology that eliminates background noise. Connect to a computer with the included BT700 USB-A adapter and to a mobile via Bluetooth v5.2. Phenomenal flexibility, connectivity and freedom? Yes please!
Noise-canceling dual mic with Acoustic Fence technology
Audio Quality: Callers hear you - not your surroundings, with a noise-canceling dual mic with Acoustic Fence technology to block out background noise in a flexible microphone boom. -
Bluetooth 5.2
Connectivity and Mobility: Connect to a computer via BT700 Bluetooth adapter or mobile via Bluetooth 5.2. Move around freely with up to 50 m/164 ft of Bluetooth wireless range (with included BT700 USB Adapter). -
Both wired and wireless connection options
Versatility: Use wireless with the included Bluetooth adapter or as a wired headset with audio over USB cable mode. -
Single-ear headset designed to multitask
Wearing Style: Single-ear headset designed to multitask. Enjoy all day wearing thanks to a comfortable and adjustable padded headband. -
Ideal for home and office use
Ideal for: The hybrid worker needing an affordable solution to connect at home and in the office.
- Poly Voyager 4300 UC Series 4310 - headset
- Product Type
- Headset - Bluetooth - wireless - USB-A
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Mono
- Microphone
- Boom
- Microphones Included
- 2
- Controls
- Mute, volume, answer/end, play/pause, next/previous track
- Software Certification
- Zoom Certified
- 2-year warranty
- Product Type
- 21 cm
- 5.5 cm
- 18.6 cm
- 122 g
- Recommended Use
- Computer
- Max Operating Distance
- 50 m
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Mono
- Adjustable Headband
- Acoustic Fence technology
Microphone
- Boom
- 2
Remote Control
- Controls
- Included Accessories
- Bluetooth USB-A adapter
- Zoom Certified
- Battery
- Headset battery rechargeable
- Limited warranty - 2 years
