Poly Voyager 4220 Office1Way BaseUSB Voyager 4220 Office1Way BaseUSB 33
Quicklinx: G1C6WS00 Mfr#: 212721-05
Power up productivity for office workers with Voyager wireless headsets. Connecting is seamless - desk phone, smartphone or computer. Outstanding audio, freedom to roam.
  • Choice of wearing style
    In open office environments, you may want a stereo headset to listen to media or you may prefer a mono headset to hear your surroundings. Voyager 4200 UC Series delivers vibrant audio for any workstyle and preference.
  • Crystal-clear audio
    Experience crystal-clear audio, whether you're listening to multimedia or collaborating with colleagues, with Voyager 4200 UC Series. Enjoy wireless freedom while you roam the office. Vibrant sound is with you every step within the headset's 98 ft/30 m range.
  • Easily connect and manage calls
    Plantronics Voyager 4200 UC Series makes it easy to switch between PC/Mac and mobile devices, so it's easy to stay connected. A dedicated button gives you quick access to mute, while voice prompts alert you if you're on mute when you start talking. Enhanced voice alerts tell you connection status, remaining talk time, mute status and more. Your colleagues will know when you're talking to someone because of the red call indicator light. And, you'll still hear incoming calls if you step away from your desk.
  • Customize your experience
    Choose the settings to customize your headset with Plantronics Hub for mobile (iPhone and Android) and Plantronics Hub for desktop. Check remaining talk time and select your language preference, feature settings, call and mute notifications. Keep your device up-to-date with Plantronics Hub over-the-air firmware updates.
  • Seamless IT management
    Voyager 4200 UC Series is supported by Plantronics Manager Pro, a Software-as-a-Service that is sold separately. Use Plantronics Manager Pro to manage headset inventory, monitor usage and maintain devices. With actionable insights from Plantronics Manager Pro, IT can improve business processes, employee performance and compliance.
  • Alexa built in
    Tap. Ask. Listen. You can talk to the Amazon Alexa app on your mobile with your Bluetooth connected Voyager headset. You can tap-and-ask Alexa to play music, hear the news, check weather, and more.
Poly Voyager 4220 Office - 1-way base - headset
Headset - Bluetooth - wireless
Recommended Use
Phone
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 94 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional
Microphones Included
2
Controls
Mute, volume, answer/end, play/pause, next/previous track
Series
Office Series
150 g
Recommended Use
Phone
Voice alerts
Max Operating Distance
91 m
Audio Output
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, mSBC
Bluetooth Version
Bluetooth 5.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
94 dB
Impedance
32 Ohm
Diaphragm
32 mm
Volume Limiting Function
SoundGuard DIGITAL Technology
Microphone
Boom
Uni-directional
2
Remote Control
Controls
Cable Details
USB cable
Bluetooth Class 1
Headset battery rechargeable - lithium polymer
360 mAh
Run Time (Up To)
12 hour(s)
Run Time Details
Continuous playback: up to 15 hours , Continuous talk: up to 12 hours
Standby Time
312 hours
Recharge Time
1.5 hour(s)
