Power up productivity for office workers with Voyager wireless headsets. Connecting is seamless - desk phone, smartphone or computer. Outstanding audio, freedom to roam.
Choice of wearing style
In open office environments, you may want a stereo headset to listen to media or you may prefer a mono headset to hear your surroundings. Voyager 4200 UC Series delivers vibrant audio for any workstyle and preference. -
Crystal-clear audio
Experience crystal-clear audio, whether you're listening to multimedia or collaborating with colleagues, with Voyager 4200 UC Series. Enjoy wireless freedom while you roam the office. Vibrant sound is with you every step within the headset's 98 ft/30 m range. -
Easily connect and manage calls
Plantronics Voyager 4200 UC Series makes it easy to switch between PC/Mac and mobile devices, so it's easy to stay connected. A dedicated button gives you quick access to mute, while voice prompts alert you if you're on mute when you start talking. Enhanced voice alerts tell you connection status, remaining talk time, mute status and more. Your colleagues will know when you're talking to someone because of the red call indicator light. And, you'll still hear incoming calls if you step away from your desk. -
Customize your experience
Choose the settings to customize your headset with Plantronics Hub for mobile (iPhone and Android) and Plantronics Hub for desktop. Check remaining talk time and select your language preference, feature settings, call and mute notifications. Keep your device up-to-date with Plantronics Hub over-the-air firmware updates. -
Seamless IT management
Voyager 4200 UC Series is supported by Plantronics Manager Pro, a Software-as-a-Service that is sold separately. Use Plantronics Manager Pro to manage headset inventory, monitor usage and maintain devices. With actionable insights from Plantronics Manager Pro, IT can improve business processes, employee performance and compliance. -
Alexa built in
Tap. Ask. Listen. You can talk to the Amazon Alexa app on your mobile with your Bluetooth connected Voyager headset. You can tap-and-ask Alexa to play music, hear the news, check weather, and more.
- Poly Voyager 4210 Office - headset
- Product Type
- Headset - Bluetooth - wireless - USB
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 94 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- Microphones Included
- 2
- Controls
- Mute, volume, answer/end, play/pause, next/previous track
- Product Type
- Series
- UC Series
- 110 g
- Voice alerts
- Max Operating Distance
- 30 m
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Mono
- 20 - 20000 Hz
- Sensitivity
- 94 dB
- Impedance
- 32 Ohm
- Diaphragm
- 32 mm
- SoundGuard Technology
Microphone
- Boom
- Uni-directional
- 2
Remote Control
- Controls
- Included Accessories
- Bluetooth USB adapter, wireless headset system base
- Battery
- Headset battery rechargeable - lithium polymer
- Capacity
- 360 mAh
- Run Time (Up To)
- 12 hour(s)
- Run Time Details
- Continuous playback: up to 15 hours , Continuous talk: up to 12 hours
- Standby Time
- 312 hours
- Recharge Time
- 1.5 hour(s)
