Poly U10P-S19 Headset Bottom Cable - RJ45(M) to Quick Disconnect/QD (F) 4m
Quicklinx: 6L2LWS00 Mfr#: 38340-01
Plantronics' mission is to enhance personal communication. Plantronics helps make people more productive, safe, and comfortable improving the clarity of communications. Plantronics is committed to ensuring that its products meet customer requirements and are committed to quality and customer satisfaction.
U10P-S19 Headset Bottom Cable - RJ45(Male) to Quick Disconnect (Female) - Cable is 4 Meters Long
  • Durable coiled design
    The coiled design of the cable enhances its durability, allowing for extended use without compromising performance.
  • Versatile connectivity options
    Featuring a male RJ-45 connector and a female Quick Disconnect, the cable provides versatile connectivity options for a variety of audio devices.
Poly U10P-S19 - headset cable - 4 m
Cable
Headset cable
Length
4 m
Connector
RJ-45 - male
Connector (Second End)
Quick Disconnect - female
Coiled
Mitel 5370, 5380, 6775, 7434, 7444; MiVoice 5380, 6771, 6773, 6775; EncorePro HW291, HW301; SupraPlus H251, H261; TriStar H81; DuoPro H151, H161, H171, H181; DuoSet H141; Encore H101, H91; Entera USB HW111, HW121; Mirage H41; SupraPlus SL H351, H361
Cable Type
Headset cable
Length
4 m
Coiled
Connector
RJ-45 - male
Mitel 5370, 5370ip, 5380, 5380ip, 6775, 7434ip, 7444ip , Mitel MiVoice 5380 IP Phone, 6771, 6773, 6773 IP, 6775, 6775 IP , Poly EncorePro HW291N, HW301N , Poly SupraPlus H251, H251 with Voice Tube, H251N, H261, H261N , Poly TriStar H81, H81N , Poly - Plantronics DuoPro H151, H151N, H161, H161N, H171, H171N, H181, H181N , Poly - Plantronics DuoSet H141, H141N , Poly - Plantronics Encore H101, H101N, H91, H91N , Poly - Plantronics Entera USB HW111N-USB, HW111N-USB-M, HW121N-USB, HW121N-USB-M , Poly - Plantronics Mirage H41, H41N , Poly - Plantronics SupraPlus SL H351 with VoiceTube, H351N, H351N with Noise Canceling, H361 with VoiceTube, H361N with Noise Canceling
