The HP Inc. Poly U10P model introduces a specialized headset cable that stands out for its long end cable feature, offering users flexibility and freedom of movement. This is particularly advantageous in dynamic environments where being tethered closely to a device can hinder productivity and comfort. Moreover, the headset cable is equipped with an AV cable type, ensuring that it provides a reliable and high-quality audio connection. This makes the HP Poly U10P an ideal choice for professionals who require consistent audio performance for communications, as well as for individuals seeking an immersive multimedia experience. The combination of mobility and superior audio connectivity makes this product a valuable addition to any tech toolkit.
Extended reach
The HP Poly U10P headset cable is designed with a long end cable, providing users with the flexibility to move around freely without compromising the connection or audio quality. This feature is especially beneficial in environments where mobility and space are crucial for productivity and comfort. -
High-quality connectivity
Featuring an AV cable type specifically for headsets, the HP Poly U10P ensures a stable and clear connection for all your audio needs. Whether for professional communication or multimedia enjoyment, this cable delivers consistent audio performance.
 - Poly U10P - headset cable
- Cable
 - Headset cable
 - Long end cable
- Cable Type
 - Headset cable
 - Long end cable
 - 74 g
- Shipping Width
 - 18.78 cm
- Shipping Depth
 - 25.4 cm
- Shipping Height
 - 2.54 cm
- Shipping Weight
 - 78 g
