Poly U10 Bottom Cable for Cisco & IP Telephones
Quicklinx: 4C2WWS00 Mfr#: 26716-01
Plantronics is a world's leading designer, manufacturer and marketer of lightweight communications headset products. The company also produces products for the computer and mobile market segments, specialty telephone products, such as amplified telephone headsets, telephones for hearing-impaired users and noise-canceling headsets and handsets for use in high-noise environments. Plantronics knows that an audio device such as a headset is nothing without the proper connection to the receiver or the transmitter. So Plantronics offers a wide range of cabling solutions to provide reliable connection to your equipment and to give you the clearest, noise-free sound possible.
Poly headset amplifier cable - 3 m
Cable
Headset amplifier cable
Length
3 m
Connector
Quick Disconnect
Connector (Second End)
Headset amplifier modular plug
Coiled
Cisco IP Phone 78XX, 79XX, 88XX; Unified IP Phone 6945, 79XX, 89XX; Unified Wireless IP Phone 7921; EncorePro HW291, HW301; SupraPlus H251, H261; TriStar H81; DuoPro H151, H161, H171, H181; DuoSet H141; Encore H101, H91; Entera USB HW111, HW121; Mirage H41; SupraPlus SL H351, H361
Cable Type
Length
3 m
Coiled
Connector
Quick Disconnect
Cisco IP Phone 7821, 7841, 7861, 7940, 7960, 7960G, 7961G, 7970G, 8811, 8841, 8865 , Cisco Unified IP Phone 6945 Slimline, 6945 Standard, 7931G, 7940, 7941G, 7942G, 7945G, 7962G, 7965G, 7970G, 7971G, 7975G, 8941 Slimline, 8941 Standard, 8945 Slimline, 8945 Standard , Cisco Unified Wireless IP Phone 7921G , Poly EncorePro HW291N, HW301N , Poly SupraPlus H251, H251 with Voice Tube, H251N, H261, H261N , Poly TriStar H81, H81N , Poly - Plantronics DuoPro H151, H151N, H161, H161N, H171, H171N, H181, H181N , Poly - Plantronics DuoSet H141, H141N , Poly - Plantronics Encore H101, H101N, H91, H91N , Poly - Plantronics Entera USB HW111N-USB, HW111N-USB-M, HW121N-USB, HW121N-USB-M , Poly - Plantronics Mirage H41, H41N , Poly - Plantronics SupraPlus SL H351 with VoiceTube, H351N, H351N with Noise Canceling, H361 with VoiceTube, H361N with Noise Canceling
