Poly Sync 60 Smart Speakerphone - Certified for Microsoft Teams
Quicklinx: GXSMWS00 Mfr#: 216873-01
Everyone deserves to hear the whole meeting-loud and clear. Poly Sync 60-M USB/Bluetooth smart speakerphone is perfect for conference rooms. Voices are the focus, not the noise, so no one misses a thing. Fill the room with remarkable sound using powerful twin speakers. And with simple, flexible connectivity options, joining meetings couldn't be easier.
  • Loud and clear with powerful high-performance speakers
    Fill the conference room with remarkable sound thanks to the beautifully engineered twin-speakers. The six-microphone array ensures everyone in the room has a voice while helping to keep echo and noise out.
  • Connect instantly to start any meeting
    Users enjoy easy connectivity however they want to work - connect wirelessly via Bluetooth or wired via combined USB-A/USB-C cable. And with a built in USB video camera input moving from an audio to video call is super easy.
  • No complex setup, no user training, no headaches for it
    Just deploy and you're done - no new interface to learn - teams use their own devices, and work in the collaboration applications they're comfortable with. For IT, inventory tracking and updates are made easy with remote device management.
  • Create large conference spaces
    Wirelessly pair two units together for your larger meeting space needs.
Poly Sync 60 - smart speakerphone - USB-A, USB-C
Smart speakerphone - Bluetooth - wired, wireless - NFC - USB-A, USB-C
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer - communication
Additional Functions
USB charging port
Wired, wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Stereo
Sound Effects
Bass Reflex System
Audio Specifications
Frequency Response 75 - 20000 Hz
Microphones Included
6
Controls
Answer/end, mute, volume, power on/off, pair mode, daisy chain, programmable button, Microsoft Teams button
Software Certification
Compatibility
Mac, Windows
USB charging port
39.4 cm
12.2 cm
3.7 cm
1 kg
Recommended Use
Noise reduction, touch control, Kensington lock secure slot
Audio Output
Wired, wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Sound Effects
Bass Reflex System
Frequency Response
75 - 20000 Hz
Diaphragm
50 mm
Acoustic echo cancelation
Microphone
Microphone array
6
Frequency Response
100 - 6700 Hz
Echo-cancelling
Remote Control
Controls
Connector Type
USB (USB Type-A) , USB (24 pin USB-C)
Power adapter
Cable Details
USB cable - 1.5 m
