Poly Sync 40+ Speakerphone (with Poly BT600)
Quicklinx: G8BBWS00 Mfr#: 218765-01
Business moves fast. Joining virtual meetings should be fast, too. Poly Sync 40+ USB/ Bluetooth smart speakerphone lets users get straight to work. Designed for flexible and huddle workspaces, its sound is remarkable. Everyone can hear and be heard with its multi-microphone array and full-duplex audio. Intuitive features ensure smooth and easy conferencing. Flexible, simple, smart.
Poly Sync 40+ (with Poly BT600) - smart speakerphone
Smart speakerphone - Bluetooth - wireless, wired - USB
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer - communication
Additional Functions
USB charging port
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Audio Specifications
Frequency Response 75 - 20000 Hz
Microphone
Tabletop
Microphones Included
3
Controls
Mute, volume, power on/off, answer/end, programmable button, pair mode, daisy chain
Compatibility
Mac, Windows
USB charging port
27.3 cm
10.2 cm
3.8 cm
610 g
Recommended Use
Kensington lock secure slot, touch control, noise reduction
Protection
Dust-resistant, water-resistant, IP64
Audio Output
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Frequency Response
75 - 20000 Hz
Diaphragm
50 mm
Acoustic echo cancelation
Microphone
Built-in
Recommended Placing
Tabletop
3
Frequency Response
100 - 6700 Hz
Echo-cancelling
Remote Control
Controls
Connector Type
USB (USB Type-A) , USB (power only) (4 pin USB Type A (power only))
Bluetooth USB-A adapter
Cable Details
USB cable - detachable - 1.05 m , USB-A to USB-C adapter - detachable
IP64
Speaker phone battery rechargeable - Lithium Ion
5000 mAh
Run Time (Up To)
30 hour(s)
Run Time Details
Continuous talk: up to 30 hours
Recharge Time
5 hour(s)
