Let's face it: the audio on your laptop and smartphone aren't great. Sound like the professional you are with Poly Sync 20 USB/Bluetooth smart speakerphone-for remarkable conference calls and music anywhere. Take it wherever you go-its battery lasts for hours. You'll always hear and be heard.
- Poly Sync 20 - smart speakerphone - USB-A
- Product Type
- Smart speakerphone - Bluetooth - wired, wireless - USB-A
- Compatibility
- Mac, Windows
- Recommended Use
- Portable electronics
- Additional Functions
- USB charging port
- Connectivity Technology
- Wired, wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Mono
- Sound Effects
- Bass Reflex System
- Audio Specifications
- Frequency Response 80 - 20000 Hz
- Microphones Included
- 3
- Controls
- Answer/end, mute, volume, power on/off, pair mode
- Product Type
- Compatibility
- Mac, Windows
- USB charging port
- 18.2 cm
- 9.5 cm
- 3.4 cm
- 350 g
- Recommended Use
- Noise reduction, touch control, Kensington lock secure slot
- Protection
- IP64, dust-resistant, water-resistant
Audio Output
- Wired, wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Mono
- Sound Effects
- 80 - 20000 Hz
- Diaphragm
- 40 mm
- Acoustic echo cancelation
Microphone
- Form Factor
- Built-in
- 3
- 100 - 6700 Hz
Remote Control
- Controls
- Connector Type
- USB (USB Type-A) , USB (power only) (4 pin USB Type A (power only))
- Included Accessories
- Carrying case, lanyard
- Cable Details
- USB cable - 71 cm
- IP64
- Battery
- Speaker phone battery rechargeable - Lithium Ion
- Capacity
- 3200 mAh
- Run Time (Up To)
- 20 hour(s)
- Recharge Time
- 4 hour(s)
