Poly SYNC 20 SY20 M USB C WW
Quicklinx: G1D4WS00 Mfr#: 216870-01
Let's face it: the audio on your laptop and smartphone aren't great. Sound like the professional you are with Poly Sync 20 USB/Bluetooth smart speakerphone-for remarkable conference calls and music anywhere. Take it wherever you go-its battery lasts for hours. You'll always hear and be heard.
  • Versatile connectivity
    With both wired and wireless connectivity options, including Bluetooth 5.1, the Poly Sync 20 for Microsoft Teams offers flexibility for users on-the-go. Whether at home, in the office, or moving between locations, seamless connection to portable electronics is provided.
  • Superior audio quality
    Engineered with a Bass Reflex System and a wide frequency response range of 80 - 20,000 Hz for audio output, this smart speakerphone delivers crisp, clear sound. The built-in microphone with a frequency response of 100 - 6700 Hz ensures your voice is heard clearly on the other end, making every call productive.
  • Durable design
    Designed to withstand the rigors of daily use, the Poly Sync 20 is both dust-resistant and water-resistant, with an IP64 protection rating. This durability ensures the device remains reliable in various environments, from busy offices to outdoor workspaces.
  • Intuitive controls
    Featuring touchscreen control for easy operation, along with dedicated buttons for Microsoft Teams, answer/end calls, mute, pair mode, power on/off, and volume adjustments. This level of control enhances user experience, making it easier to manage calls and multimedia playback.
  • Long-lasting battery life
    Equipped with a 3200 mAh lithium-ion rechargeable battery, the Poly Sync 20 provides extended use with up to 4 hours of recharge time. This feature ensures you stay connected and productive throughout the day without worrying about frequent recharges.
Poly Sync 20 for Microsoft Teams - smart speakerphone - USB-C
Smart speakerphone - Bluetooth - wired, wireless - USB-C
Compatibility
Mac, Windows
Recommended Use
Portable electronics
Additional Functions
USB charging port
Wired, wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Audio Specifications
Frequency Response 80 - 20000 Hz
Microphones Included
3
Controls
Answer/end, mute, volume, power on/off, pair mode, Microsoft Teams button
Compatibility
Mac, Windows
USB charging port
18.2 cm
9.5 cm
3.4 cm
350 g
Recommended Use
Noise reduction, touch control, Kensington lock secure slot
Protection
IP64, dust-resistant, water-resistant
Audio Output
Wired, wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Frequency Response
80 - 20000 Hz
Diaphragm
40 mm
Acoustic echo cancelation
Microphone
Built-in
3
Frequency Response
100 - 6700 Hz
Remote Control
Controls
Connector Type
USB (USB Type-C) , USB (power only) (4 pin USB Type A (power only))
Carrying case, lanyard
Cable Details
USB-C cable - 71 cm
IP64
Speaker phone battery rechargeable - Lithium Ion
3200 mAh
Run Time (Up To)
20 hour(s)
Recharge Time
4 hour(s)
