Sound like the professional you are with Poly Sync 20 USB/Bluetooth smart speakerphone - for conference calls and music anywhere you work. Take it wherever you go - it's got up to 20 hours of talk time.
                Three-microphone arrayExperience conference calls with outside noise and distractions tuned out. A three-microphone array focuses on your voice - not the surrounding noise.
                Full-duplex audioCollaboration gets tough when one voice dominates the conversation. Full-duplex audio makes simultaneous conversations a breeze.
                Smartphone chargerStay connected and ready for your calls with the ability to charge your smartphone when on the go via an USB-A port.
                Up to 20 hours of battery lifeWork on the go - the battery is ready for portable use with up to 20 hours of talk time on a full charge.
                Wireless connectionEnjoy easy connectivity, however you want to work with your devices - connect smartphones wirelessly via Bluetooth or to the computer with the integrated USB-A or USB Type-C ? cable.
                Certified for Microsoft TeamsFull Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more.
- Poly Sync 20 - smart speakerphone - USB-A
- Product Type
- Smart speakerphone - Bluetooth - wired, wireless - USB-A
- Compatibility
- Windows, Mac
- Recommended Use
- Portable electronics
- Additional Functions
- USB charging port
- Silver
- Connectivity Technology
- Wired, wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Mono
- Sound Effects
- Bass Reflex System
- Audio Specifications
- Frequency Response 80 - 20000 Hz
- Microphones Included
- 3
- Controls
- Answer/end, mute, volume, power on/off, pair mode, Microsoft Teams button
- Software Certification
- Certified for Microsoft Teams
- Product Type
- Compatibility
- Windows, Mac
- USB charging port
- 18.2 cm
- 9.5 cm
- 3.4 cm
- 360 g
- Silver
- Recommended Use
- Noise reduction, touch control
Audio Output
- Wired, wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Mono
- Sound Effects
- 80 - 20000 Hz
- Max Sound Pressure
- 86 dB
- Diaphragm
- 40 mm
- Acoustic echo cancelation
Microphone
- Form Factor
- Built-in
- 3
Remote Control
- Controls
- Connector Type
- USB (USB Type-A) , USB (power only) (4 pin USB Type A (power only))
- Included Accessories
- Carrying case, lanyard
- Cable Details
- USB cable - 71.5 cm
- Battery
- Speaker phone battery rechargeable - Lithium Ion
- Capacity
- 3200 mAh
- Run Time (Up To)
- 20 hours
- Recharge Time
- 4 hours
- Shipping Width
- 20.9 cm
- Shipping Depth
- 18.3 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 540 g
