Poly Sync 20 SY20-M USB-A WW
Quicklinx: HM4PWS00 Mfr#: 772C8AA
£60.87 ex VAT
£73.04 inc VAT
Sound like the professional you are with Poly Sync 20 USB/Bluetooth smart speakerphone - for conference calls and music anywhere you work. Take it wherever you go - it's got up to 20 hours of talk time.
  • Three-microphone array
    Experience conference calls with outside noise and distractions tuned out. A three-microphone array focuses on your voice - not the surrounding noise.
  • Full-duplex audio
    Collaboration gets tough when one voice dominates the conversation. Full-duplex audio makes simultaneous conversations a breeze.
  • Smartphone charger
    Stay connected and ready for your calls with the ability to charge your smartphone when on the go via an USB-A port.
  • Up to 20 hours of battery life
    Work on the go - the battery is ready for portable use with up to 20 hours of talk time on a full charge.
  • Wireless connection
    Enjoy easy connectivity, however you want to work with your devices - connect smartphones wirelessly via Bluetooth or to the computer with the integrated USB-A or USB Type-C ? cable.
  • Certified for Microsoft Teams
    Full Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more.
Poly Sync 20 - smart speakerphone
Smart speakerphone - Bluetooth - wireless, wired - USB-A
Compatibility
Mac, Windows
Recommended Use
Portable electronics
Additional Functions
USB charging port
Silver
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Audio Specifications
Frequency Response 80 - 20000 Hz
Microphones Included
3
Controls
Mute, volume, power on/off, answer/end, pair mode, Microsoft Teams button
Software Certification
Compatibility
Mac, Windows
USB charging port
18.2 cm
9.5 cm
3.4 cm
360 g
Silver
Recommended Use
Touch control, noise reduction
Audio Output
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Frequency Response
80 - 20000 Hz
Max Sound Pressure
86 dB
Diaphragm
40 mm
Acoustic echo cancelation
Microphone
Built-in
3
Remote Control
Controls
Connector Type
USB (USB Type-A) , USB (power only) (4 pin USB Type A (power only))
Carrying case, lanyard
Cable Details
USB cable - 71.5 cm
Speaker phone battery rechargeable - Lithium Ion
3200 mAh
Run Time (Up To)
20 hours
Recharge Time
4 hours
Shipping Width
20.9 cm
Shipping Depth
18.3 cm
Shipping Height
5.5 cm
Shipping Weight
540 g
Brand: Poly
