Poly SYNC 20 SY20 M USB A WW
Quicklinx: G1D0WS00 Mfr#: 216866-01
21 left in stock
£69.65 ex VAT
£83.58 inc VAT
Express delivery Order within the next 5 hours for delivery tomorrow
Let's face it: the audio on your laptop and smartphone aren't great. Sound like the professional you are with Poly Sync 20 USB/Bluetooth smart speakerphone-for remarkable conference calls and music anywhere. Take it wherever you go-its battery lasts for hours. You'll always hear and be heard.
  • Grab the perfect speakerphone for meetings and music, wherever your day takes you
    Let's face it: the audio on your laptop and smartphone aren't great. Sound like the professional you are with Poly Sync 20 USB/Bluetooth smart speakerphone - for remarkable audio anywhere. The Poly Sync 20 is Zoom certified and available in a Microsoft Teams certified version.
  • Keep the focus on your voice with multi-microphones that track the talker, not the noise
    Focus on what's being said and help keep echo and noise out of the meeting with the smart multi-microphone array. You and your remote participants sound amazing with the high-performance speaker.
  • Program your favorite function so it works with a single touch
    A programmable button puts your favorite function at your fingertips - play/pause music, last-number redial and voice assistant - it's up to you. What's the status of a call? You'll know even from a distance by the highly visible light bar.
  • You're ready for anything from meetings to music to charging your smartphone
    The internal battery is ready to go with up to 20 hours of portable use on a full charge. You can even use it to charge your smartphone via USB.
Poly Sync 20 for Microsoft Teams - smart speakerphone - USB-A
Smart speakerphone - Bluetooth - wired, wireless - USB-A
Compatibility
Mac, Windows
Recommended Use
Portable electronics
Additional Functions
USB charging port
Wired, wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Audio Specifications
Frequency Response 80 - 20000 Hz
Microphones Included
3
Controls
Answer/end, mute, volume, power on/off, pair mode, Microsoft Teams button
Compatibility
Mac, Windows
USB charging port
18.2 cm
9.5 cm
3.4 cm
350 g
Recommended Use
Noise reduction, touch control
Protection
IP64, dust-resistant, water-resistant
Audio Output
Wired, wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.1
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
Sound Effects
Bass Reflex System
Frequency Response
80 - 20000 Hz
Diaphragm
40 mm
Acoustic echo cancelation
Microphone
Built-in
3
Frequency Response
100 - 6700 Hz
Remote Control
Controls
Connector Type
USB (USB Type-A) , USB (power only) (4 pin USB Type A (power only))
Carrying case, lanyard
Cable Details
USB cable - 71 cm
IP64
Speaker phone battery rechargeable - Lithium Ion
3200 mAh
Run Time (Up To)
20 hour(s)
Recharge Time
4 hour(s)
Brand: Poly
Stock Status: While stocks last
Stock Status: Clearance
