Turn your home office into a conference room. The all-in-one Poly Sync 10 USB speakerphone delivers high-quality audio that's great for voice and music. Its two-microphone array reduces surrounding noise for better conference calls.
                Two-microphone arrayExperience conference calls with outside noise and distractions tuned out. A two-microphone array focuses on your voice - not the surrounding noise.
                Hi-fi audio and power amplifierExpect high-quality performance for calls and while listening to podcasts or music thanks to the reliable, enterprise-grade hi-fi audio and power amplifier.
                Full-duplex audioCollaboration gets tough when one voice dominates the conversation. Full-duplex audio makes simultaneous conversations a breeze.
                Touch-sensitive controlsIt's easy to spot and control your call status directly on the device. Stay in control with easy-to-use, touch-sensitive controls and a clear LED indicator.
                Dust-and-water resistantAccidents happen - especially on the go. That's why durability is top of mind. Protect your investment from real-life hazards with a device that's IP64 dust and water-resistant.
                Certified for Microsoft TeamsFull Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more.
- Poly Sync 10-M - speakerphone - USB-A, USB-C
- Product Type
- Speakerphone - wired - USB-A, USB-C
- Compatibility
- Windows, Mac
- Recommended Use
- Computer
- Silver
- Connectivity Technology
- Wired
- Microphones Included
- 2
- Controls
- Answer/end, mute, volume
- Software Certification
- Certified for Microsoft Teams
- Product Type
- Compatibility
- Windows, Mac
- 18.2 cm
- 8.9 cm
- 3.3 cm
- 280 g
- Silver
- Recommended Use
- Computer
- Touch control, noise reduction
Audio Output
- Wired
- Diaphragm
- 40 mm
- Echo cancelation
Microphone
- Form Factor
- Built-in
- 2
- Frequency Response
- 100 - 7800 Hz
Remote Control
- Controls
- Connector Type
- USB (USB Type-A)
- Software Included
- Plantronics Manager Pro, Poly Lens
- Included Accessories
- USB-C adapter
- Cable Details
- USB cable - 71.5 cm
- Supported Host Device OS
- Windows 10, macOS
- Shipping Width
- 19.98 cm
- Shipping Depth
- 9.29 cm
- Shipping Height
- 4.08 cm
- Shipping Weight
- 350 g
