Poly Studio P5 kit with Sync 20+
Quicklinx: G6FCWS00 Mfr#: 2200-87150-025
The Poly Studio P5 Kit with Poly Sync 20+ has everything you need for professional video conferencing and is the ideal solution for dedicated offices and workspaces. It includes a webcam and smart speakerphone all in one package that's easy to set up. Exceptional camera optics are fine-tuned so you always come across clearly with a powerful, professional-quality image. The powerful speakerphone ensures you always hear and be heard. For IT, the single-box design simplifies ordering and deployment, while Poly Lens cloud management provides robust tools to manage and track devices from anywhere.
  • Everything you need
    Packaged together as one, the Poly Studio P5 Kit is super-simple to setup and lets you choose the audio device that best suits how and where you work.
  • Pro-grade camera optics
    Automatic low-light compensation and brilliant colors make you look your best, without being left in the dark. The 1080p resolution with 4x digital zoom camera puts the focus on you, right where it belongs.
  • Look like a pro, sound like a pro
    Ready to go next level? Poly Studio P5 Kit with Poly Sync 20+ includes a professional webcam and smart Bluetooth/USB speakerphone all in one package.
Poly Studio P5 - webcam - with Poly Sync 20+ Speakerphone
Webcam
Bundled with
Audio
Yes: built-in directional microphone
Camera Mount Type
Tripod mount
3.77 cm x 3.4 cm x 6.2 cm
68 g
Wired
Camera
Video Modes
720p, 1080p
Focus Adjustment
Automatic
USB 2.0
USB cable - integrated
ePTZ, privacy shutter, Low Light Compensation (LLC)
Environmental Parameters (operating)
0 °C - 40 °C; 5 - 95% (non-condensing) relative humidity
Webcam
Audio Support
Camera Mount Type
Tripod mount
Wired
3.77 cm
3.4 cm
6.2 cm
68 g
Worldwide
Bundled with
Camera
Video Modes
720p, 1080p
Digital Zoom
4
Lens Construction
Focus Adjustment
Automatic
Diagonal Field of View (degree)
80
Computer Interface
USB 2.0
Ports
USB - 4 pin USB Type A
Monitor mount
Plug and Play
Apple MacOS X 10.7 or later, Windows 8.1, Windows 10
Relative Humidity (operating)
