Poly Studio P5 kit with Blackwire 3325
Quicklinx: G6F0WS00 Mfr#: 2200-87130-025
The Poly Studio P5 Kit with Blackwire 3325 has everything you need for a professional video conferencing experience at home or wherever you're working. It includes a webcam and stereo headset all in one package that's easy to set up. Exceptional camera optics are fine-tuned so you always come across clearly with a powerful, professional-quality image. The headset is comfortable to wear, easy to use, and features crisp stereo audio. For IT, the single-box design simplifies ordering and deployment, while Poly Lens cloud management provides robust tools to manage and track devices from anywhere.
  • Everything you need
    Packaged together as one, the Poly Studio P5 Kit is super-simple to setup and lets you choose the audio device that best suits how and where you work.
  • Pro-grade camera optics
    Automatic low-light compensation and brilliant colors make you look your best, without being left in the dark. The 1080p resolution with 4x digital zoom camera puts the focus on you, right where it belongs.
  • Avoid the not-so-funny video fails
    The clothing-optional kid. The dog starved for attention. You may be camera ready, but everything behind you may not be. The integrated privacy shutter on the Poly Studio P5 gives you an extra level of control to ensure you're not seen at the wrong time. Along with anyone else.
Poly Studio P5 - webcam - with Poly Blackwire 3325 Headset
Webcam
Bundled with
Audio
Yes: built-in directional microphone
Camera Mount Type
Tripod mount
3.77 cm x 3.4 cm x 6.2 cm
68 g
Wired
Camera
Video Modes
720p, 1080p
Focus Adjustment
Automatic
USB 2.0
USB cable - integrated
ePTZ, privacy shutter, Low Light Compensation (LLC)
Environmental Parameters (operating)
0 °C - 40 °C; 5 - 95% (non-condensing) relative humidity
Webcam
Audio Support
Camera Mount Type
Tripod mount
Wired
3.77 cm
3.4 cm
6.2 cm
68 g
Worldwide
Bundled with
Camera
Video Modes
720p, 1080p
Digital Zoom
4
Lens Construction
Focus Adjustment
Automatic
Diagonal Field of View (degree)
80
Computer Interface
USB 2.0
Ports
USB - 4 pin USB Type A
Monitor mount
Plug and Play
Apple MacOS X 10.7 or later, Windows 8.1, Windows 10
Relative Humidity (operating)
