The Poly Studio P5 Kit with Blackwire 3210 has everything you need for a professional video conferencing experience at home or wherever you're working. It includes a webcam and single-ear headset all in one package that's easy to set up. Exceptional camera optics are fine-tuned so you always come across clearly with a powerful, professional-quality image. The headset is comfortable to wear, easy to use, and keeps one ear free to stay aware of the surrounding environment. For IT, the single-box design simplifies ordering and deployment, while Poly Lens cloud management provides robust tools to manage and track devices from anywhere.
Everything you need
Packaged together as one, the Poly Studio P5 Kit is super-simple to setup and lets you choose the audio device that best suits how and where you work. -
Pro-grade camera optics
Automatic low-light compensation and brilliant colors make you look your best, without being left in the dark. The 1080p resolution with 4x digital zoom camera puts the focus on you, right where it belongs. -
Avoid the not-so-funny video fails
The clothing-optional kid. The dog starved for attention. You may be camera ready, but everything behind you may not be. The integrated privacy shutter on the Poly Studio P5 gives you an extra level of control to ensure you're not seen at the wrong time. Along with anyone else.
- Poly Studio P5 - webcam - with Poly Blackwire 3210 Headset
- Webcam
- Bundled with
- Poly Blackwire 3210 Headset
- Audio
- Yes: built-in directional microphone
- Camera Mount Type
- Tripod mount
- 3.77 cm x 3.4 cm x 6.2 cm
- 68 g
- Connectivity Technology
- Wired
- Camera
- Video Modes
- 720p, 1080p
- Focus Adjustment
- Automatic
- USB 2.0
- Cables Included
- USB cable - integrated
- ePTZ, privacy shutter, Low Light Compensation (LLC)
- 2-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 5 - 95% (non-condensing) relative humidity
- Webcam
- Audio Support
- Camera Mount Type
- Tripod mount
- Wired
- 3.77 cm
- 3.4 cm
- 6.2 cm
- 68 g
- Localisation
- Worldwide
- Bundled with
Camera
- Video Modes
- 720p, 1080p
- Digital Zoom
- 4
Lens Construction
- Focus Adjustment
- Automatic
- Diagonal Field of View (degree)
- 80
- Computer Interface
- USB 2.0
- Ports
- USB - 4 pin USB Type A
- Included Accessories
- Monitor mount
- Cables Included
- Plug and Play
- OS Required
- Apple MacOS X 10.7 or later, Windows 8.1, Windows 10
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 5 - 95% (non-condensing)
