Poly Studio P5 - 1080P HD Camera - USB
Quicklinx: G6DYWS00 Mfr#: 2200-87070-001
The Poly Studio P5 webcam ensures you look your best on video calls at home, in the office, or wherever you're working. Exceptional camera optics are fine-tuned so you always come across clearly with a professional-quality image. Brilliant colors and automatic low light compensation deliver excellent video quality no matter where you need to take a call. The directional microphone focuses on your voice and not the noise around you. An integrated privacy shutter keeps you in control of when you are on camera for enhanced security and privacy. For IT, Poly Lens cloud management provides robust tools to manage and track devices from anywhere.
  • Meet like you mean it
    Do wonders for your professional image with the Poly Studio P5 webcam. Fine-tuned Poly optics make you look so good that you'll own the conversation. All in a small, rugged webcam that's super easy to set up and use. It's even simple for IT to manage with Poly Lens.
  • Pro-grade camera optics
    Automatic low-light compensation and brilliant colors make you look your best, without being left in the dark. The 1080p resolution with 4x digital zoom camera puts the focus on you, right where it belongs.
  • Focused directional microphone
    The Poly Studio P5's directional microphone clearly captures your voice while ignoring the distracting noise that interrupts your calls. For the best experience, pair it with a Poly headset or speakerphone so you're ready to tackle your most critical conversations with confidence.
  • Space saver
    Streamline your setup by using a Poly headset or speakerphone connected wirelessly to the Poly Studio P5 webcam. Just pop open the rear garage door, park your USB-A wireless adapter and presto! Your audio and video are ready to go.
  • Avoid the not-so-funny video fails
    The clothing-optional kid. The dog starved for attention. You may be camera ready, but everything behind you may not be. The integrated privacy shutter on the Poly Studio P5 gives you an extra level of control to ensure you're not seen at the wrong time. Along with anyone else.
Poly Studio P5 - webcam
Webcam
Audio
Yes: built-in directional microphone
Camera Mount Type
Tripod mount
3.77 cm x 3.4 cm x 6.2 cm
68 g
Wired
Camera
Video Modes
720p, 1080p
Focus Adjustment
Automatic
USB 2.0
USB cable - integrated
ePTZ, privacy shutter, Low Light Compensation (LLC)
Works With Chromebook
Environmental Parameters (operating)
0 °C - 40 °C; 5 - 95% (non-condensing) relative humidity
Webcam
Audio Support
Camera Mount Type
Tripod mount
Wired
3.77 cm
3.4 cm
6.2 cm
68 g
Worldwide
Camera
Video Modes
720p, 1080p
Digital Zoom
4
Lens Construction
Focus Adjustment
Automatic
Diagonal Field of View (degree)
80
Computer Interface
USB 2.0
Ports
USB - 4 pin USB Type A
Monitor mount
Plug and Play
Apple MacOS X 10.7 or later, Windows 8.1, Windows 10
Relative Humidity (operating)
