Poly Studio P21, 21.5", HD Camera - UK
Quicklinx: G6FHWS00 Mfr#: 2200-87100-102
38 In Stock
£59.70 ex VAT
£71.64 inc VAT
Express delivery Order within the next hour for delivery tomorrow
Combining the exceptional audio and video quality you expect from Polycom with the simplicity you need for everyday use, Polycom Studio is the USB video bar ideal for smaller rooms and huddle spaces. Its plug-and-play functionality works with nearly any video platform and fits any budget.
  • Supercharge your video calls
    Supercharge your video calls with the Poly Studio P21. Everything you need for a pro-grade video experience is ready to go with a single USB connection that works with any video app. A brilliant 21" display and built-in high-definition camera, hi-fidelity speakers, microphone and adjustable ambient lighting will make you look and sound crazy good.
  • See what you've been missing
    The pro-grade conferencing display delivers exceptional brightness and vibrant colors. You will no longer miss facial cues or spreadsheet details. And it makes an awesome second or backup display when not on video calls.
  • Never miss a beat
    Rich full-fidelity stereo speakers ensure you'll never miss a word. And the advanced microphone delivers confidence you're always heard loud and clear. No shouting required.
  • The freedom to work how you want
    There's nothing to learn. The Poly Studio P21 works with the video apps you already know. A simple USB connection to your PC or Mac will transform your video conferencing experience. Volume and mute buttons ensure control is always within reach without fumbling for your mouse.
  • Built-in lighting illuminates you clearly
    With dynamic, adjustable built-in lighting, you can count on looking your best and brightest in any light.
Poly Studio P21 - LCD monitor - Full HD (1080p) - 21.5"
LCD monitor - 21.5"
Energy Class
Class F
FHD camera, USB 2.0 hub, wireless charger
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
USB-C
Audio Input
Quad array microphone
Built-in Webcam
1080p
57.5 cm x 18.8 cm x 47.8 cm
6.8 kg
United Kingdom
Plug and Play, RoHS, halogen-free
Display Type
LCD monitor / TFT active matrix
Energy Class
Class F
Energy Class (HDR)
Class F
Diagonal Size
21.5"
Built-in Devices
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Ambient light sensor, Microsoft Teams/Zoom app button
57.5 cm x 18.8 cm x 47.8 cm - with stand
6.8 kg
Built-in Webcam
Max Video Resolution
1080p
Digital Zoom
4
Digital PTZ function, privacy shutter, 80° diagonal field of view
Audio Input
Microphone Operation Mode
Uni-directional
Sensitivity
-26 dB
Frequency Response
50 - 20000 Hz
Audio
Speakers - stereo
Output Power / Channel
10 Watt
USB-C 3.0 , 2 x USB 2.0 (power up to 5W)
Mechanical
VESA Mounting Interface
Security lock slot (cable lock sold separately), volume control
1 x USB-C to USB-C / USB-A cable - 1 m
Software Certification
Certified for Microsoft Teams
United Kingdom
Security Slot Type
Kensington security slot
16 kWh/1000h
Power Consumption HDR (On mode)
0.2 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption (Max)
50 Watt
Power Consumption Sleep
0.8 Watt
Windows 8.1 / 10, Apple macOS 10.14.6 or later
Shipping Width
69 cm
Shipping Depth
51 cm
Shipping Height
22.8 cm
Shipping Weight
10.81 kg
15 - 80% (non-condensing)
Brand: Poly
