Combining the exceptional audio and video quality you expect from Polycom with the simplicity you need for everyday use, Polycom Studio is the USB video bar ideal for smaller rooms and huddle spaces. Its plug-and-play functionality works with nearly any video platform and fits any budget.
Supercharge your video calls
Supercharge your video calls with the Poly Studio P21. Everything you need for a pro-grade video experience is ready to go with a single USB connection that works with any video app. A brilliant 21" display and built-in high-definition camera, hi-fidelity speakers, microphone and adjustable ambient lighting will make you look and sound crazy good. -
See what you've been missing
The pro-grade conferencing display delivers exceptional brightness and vibrant colors. You will no longer miss facial cues or spreadsheet details. And it makes an awesome second or backup display when not on video calls. -
Never miss a beat
Rich full-fidelity stereo speakers ensure you'll never miss a word. And the advanced microphone delivers confidence you're always heard loud and clear. No shouting required. -
The freedom to work how you want
There's nothing to learn. The Poly Studio P21 works with the video apps you already know. A simple USB connection to your PC or Mac will transform your video conferencing experience. Volume and mute buttons ensure control is always within reach without fumbling for your mouse. -
Built-in lighting illuminates you clearly
With dynamic, adjustable built-in lighting, you can count on looking your best and brightest in any light.
- Poly Studio P21 - LCD monitor - Full HD (1080p) - 21.5"
- LCD monitor - 21.5"
- Energy Class
- Class F
- FHD camera, USB 2.0 hub, wireless charger
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.24795 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- 16.7 million colours
- Input Connectors
- USB-C
- Audio Input
- Quad array microphone
- Built-in Webcam
- 1080p
- 57.5 cm x 18.8 cm x 47.8 cm
- 6.8 kg
- Localisation
- United Kingdom
- Plug and Play, RoHS, halogen-free
- 2-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Energy Class
- Class F
- Energy Class (HDR)
- Class F
- Diagonal Size
- 21.5"
- Built-in Devices
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24795 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Ambient light sensor, Microsoft Teams/Zoom app button
- 57.5 cm x 18.8 cm x 47.8 cm - with stand
- 6.8 kg
Built-in Webcam
- Max Video Resolution
- 1080p
- Digital Zoom
- 4
- Digital PTZ function, privacy shutter, 80° diagonal field of view
Audio Input
- Microphone Operation Mode
- Uni-directional
- Sensitivity
- -26 dB
- Frequency Response
- 50 - 20000 Hz
Audio
- Speakers - stereo
- Output Power / Channel
- 10 Watt
- USB-C 3.0 , 2 x USB 2.0 (power up to 5W)
Mechanical
- VESA Mounting Interface
- Security lock slot (cable lock sold separately), volume control
- Cables Included
- 1 x USB-C to USB-C / USB-A cable - 1 m
- Software Certification
- Certified for Microsoft Teams
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Power Consumption SDR (On mode)
- 16 kWh/1000h
- Power Consumption HDR (On mode)
- 0.2 kWh/1000h
- Power Consumption (Typical)
- 20 Watt
- Power Consumption (Max)
- 50 Watt
- Power Consumption Sleep
- 0.8 Watt
- OS Required
- Windows 8.1 / 10, Apple macOS 10.14.6 or later
- Shipping Width
- 69 cm
- Shipping Depth
- 51 cm
- Shipping Height
- 22.8 cm
- Shipping Weight
- 10.81 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 15 - 80% (non-condensing)
