Quality audio and video for mid-sized rooms. Poly Studio is an easy-to-use USB video bar designed for medium meeting spaces. Advanced acoustics ensure everyone sounds their best. Poly DirectorAI smart camera technology shows just enough of the room.
NoiseBlockAI technology
Distracting sounds are reduced with Poly NoiseBlockAI technology. -
Acoustic Fence technology
Keep outside conversations out of your calls with Acoustic Fence technology, which captures only the voices within a defined space. -
Microphone range
Ensure everyone in the room can be understood clearly with up to 15 ft/4.6 m microphone pickup range or add an optional expansion mic to extend that range even further. -
Hi-fidelity speakers
Hear what's being said even if you're seated at the back of the room. High-fidelity stereo speakers fill the room with sound so that remote participants can be heard clearly. -
Poly DirectorAI technology
Be more productive on both ends of your video call with a smart camera that features Poly DirectorAI smart camera tech that automatically frames the room or tracks the person speaking for deeper engagement - no drivers or software needed. -
120-degree field of view
The camera's ultra-wide field of view reaches even the back corners of a medium-sized room. See everyone while avoiding fisheye distortion with its 120-degree field of view.
- Poly Studio
- USB video bar
- Localisation
- English / United Kingdom
- Video Input
- Digital video camera
- Audio Input
- 6-microphone array - beamforming
- Audio Output
- Speaker(s) - stereo
- Power
- AC 100-240 V (50/60 Hz)
- Software Certification
- Zoom Certified, Certified for Microsoft Teams
- System Requirements
- Windows 10, Windows 8.1, Microsoft Windows 7, Apple macOS 10.12, Apple macOS 10.13, Apple macOS 10.14
- 1-year warranty
- USB video bar
- Dimensions & Weight Details
- Video bar - Width 70 cm Depth 7 cm Height 10.5 cm Weight 2.342 kg , Video bar (with stand) - Width 70 cm Depth 7 cm Height 15.6 cm Weight 2.856 kg
- Built-in Devices
- 6 microphone array, stereo speakers
- Enclosure Colour
- Black
- Localisation
Video Input
- Digital video camera - external
- Digital Video Capture Resolution
- 2160p, 3840 x 2160
- Video Modes
- 4K, 2160p
- Digital Zoom
- 5
- 120° diagonal field of view, 110° horizontal field of view (camera), Poly DirectorAI technology, Poly NoiseBlockAI technology, security slot (Kensington security lock compatible), speaker framing, presenter tracking, Conversation Mode, integrated lens cover, 4.57 m microphone pickup range, USB Device mode
Audio Input
- 6-microphone array - integrated
- Microphone Operation Mode
- Beamforming
Audio Output
- Speaker(s)
- Sound Output Mode
- Stereo
- 1 x USB-C - 24 pin USB-C , 1 x audio , 1 x microphone / audio
- Power Device
- Power adapter - external
- Voltage Required
- Software Included
- Poly Lens management software
- OS Required
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 15 - 80%
Poly Studio Expansion Microphone Cable Extenders | In Stock | £85.97 |
Poly Studio Mounting Kit (VESA mount) | In Stock | £112.78 |
Poly - USB cable - 5 m | In Stock | £68.43 |
