Poly Studio Audio/Video USB Soundbar - UK
Quicklinx: HM4CWS00 Mfr#: 842D4AA#ABU
More than 50 In Stock
£425.18 ex VAT
£510.21 inc VAT
Quality audio and video for mid-sized rooms. Poly Studio is an easy-to-use USB video bar designed for medium meeting spaces. Advanced acoustics ensure everyone sounds their best. Poly DirectorAI smart camera technology shows just enough of the room.
  • NoiseBlockAI technology
    Distracting sounds are reduced with Poly NoiseBlockAI technology.
  • Acoustic Fence technology
    Keep outside conversations out of your calls with Acoustic Fence technology, which captures only the voices within a defined space.
  • Microphone range
    Ensure everyone in the room can be understood clearly with up to 15 ft/4.6 m microphone pickup range or add an optional expansion mic to extend that range even further.
  • Hi-fidelity speakers
    Hear what's being said even if you're seated at the back of the room. High-fidelity stereo speakers fill the room with sound so that remote participants can be heard clearly.
  • Poly DirectorAI technology
    Be more productive on both ends of your video call with a smart camera that features Poly DirectorAI smart camera tech that automatically frames the room or tracks the person speaking for deeper engagement - no drivers or software needed.
  • 120-degree field of view
    The camera's ultra-wide field of view reaches even the back corners of a medium-sized room. See everyone while avoiding fisheye distortion with its 120-degree field of view.
Poly Studio
USB video bar
English / United Kingdom
Video Input
Digital video camera
Audio Input
6-microphone array - beamforming
Audio Output
Speaker(s) - stereo
AC 100-240 V (50/60 Hz)
Software Certification
Zoom Certified, Certified for Microsoft Teams
Microsoft Windows 7, Windows 8.1, Windows 10, Apple macOS 10.12, Apple macOS 10.13, Apple macOS 10.14
1-year warranty
USB video bar
Dimensions & Weight Details
Video bar - Width 70 cm Depth 7 cm Height 10.5 cm Weight 2.342 kg , Video bar (with stand) - Width 70 cm Depth 7 cm Height 15.6 cm Weight 2.856 kg
Built-in Devices
Stereo speakers, 6 microphone array
Enclosure Colour
Video Input
Digital video camera - external
Digital Video Capture Resolution
3840 x 2160, 2160p
Video Modes
2160p, 4K
Digital Zoom
5
120° diagonal field of view, integrated lens cover, Poly NoiseBlockAI technology, Poly DirectorAI technology, presenter tracking, 110° horizontal field of view (camera), Conversation Mode, security slot (Kensington security lock compatible), speaker framing, 4.57 m microphone pickup range, USB Device mode
Audio Input
6-microphone array - integrated
Microphone Operation Mode
Beamforming
Audio Output
Speaker(s)
Sound Output Mode
Stereo
1 x USB-C - 24 pin USB-C , 1 x audio , 1 x microphone / audio
Power adapter - external
Software Included
Poly Lens management software
Limited warranty - 1 year
15 - 80%
HM4C Poly Studio Expansion Microphone Cable Extenders In Stock £85.97
HM4C Poly PSU: X70/X50 & Studio USB In Stock £94.02
HM4C Poly Studio Mounting Kit (VESA mount) In Stock £109.91
Brand: Poly
