Comfortable Ear Cushions
The included ear cushions provide a snug fit, allowing for hours of comfortable wear without the typical fatigue associated with long usage. -
Quick Disconnect Convenience
The quick disconnect connector allows users to easily connect and disconnect the headset, facilitating transitions between calls and mobility. -
Flexible Coiled Cable
The coiled cable design helps manage length while reducing tangling, providing a neat and organized working space.
- Poly headset cable - 3 m
- Cable
- Headset cable
- Length
- 3 m
- Connector
- Quick Disconnect - male
- Connector (Second End)
- Micro jack - male
- Coiled
- Cable Type
- Headset cable
- Shielding Material
- Cord
- Length
- 3 m
- Coiled
- Connector
- Sub-mini phone 2.5 mm - male
