Poly Spare BT700 Bluetooth USB Adapter
Quicklinx: HSB4WS00 Mfr#: 786C4AA
£60.12 ex VAT
£72.14 inc VAT
The improved BT700 dongles with a refreshed look and compact form factor which allows you to leave it in your laptop or PC to save space! Fitted with the Bluetooth low energy technology, giving you greater wireless range and faster connection to take calls anywhere.
  • Effortless connectivity
    Experience seamless audio integration with the HP Poly BT700, designed to bring Bluetooth 5.1 wireless technology into your daily audio experiences. This advanced transmitter ensures a stable and efficient connection to your headset, providing high-quality sound without the hassle of wires.
  • Extended range
    With a maximum operating distance of 50 m, the HP Poly BT700 offers the freedom to move around without losing your audio connection. Whether you're at home or in the office, enjoy the flexibility of moving freely without interrupting your listening experience.
  • Versatile compatibility
    The HP Poly BT700 is equipped with a USB connection and supports a variety of Bluetooth profiles including A2DP, AVRCP, and HSP. This versatility ensures that your audio transmitter is compatible with a wide range of headsets, making it a suitable match for almost any setup.
Poly BT700 - Bluetooth wireless audio transmitter for headset - USB-A
Intended For
Headset
Wireless Interface
Bluetooth
1.54 cm x 2.125 cm x 0.54 cm
Blue
OMEN 40L by HP GT21-1026nd
Intended For
Headset
Wireless Interface
Bluetooth 5.1
Max Operating Distance
50 m
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Headset Profile (HSP)
1.54 cm
2.125 cm
0.54 cm
Blue
USB - USB Type-A
