The SoundStation2, Polycom's next generation conference phone, is redefining the standard for business-quality voice conferencing. With industry-leading full duplex for natural, simultaneous two-way conversation, the SoundStation2 will exceed your expectations in medium to small conference rooms. Delivering remarkable voice quality equal to the SoundStation Premier and a 50% increase in microphone sensitivity over the award-winning SoundStation, users can speak in a normal voice and be heard clearly up to ten feet away - making every call a more productive call.
- Poly SoundStation2 EX - conference phone with caller ID
- Product Type
- Conference phone with caller ID
- Speakerphone
- Yes (digital duplex)
- Caller ID
- Call Services
- Caller ID, Call Hold
- Display
- LCD display - monochrome - Yes
- 1-year warranty
- Product Type
- Conference phone
Phone Features
- Call Services
- Caller ID Type
- Caller ID
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- Speakerphone
- Function Buttons
- Conference button, menu navigation keys, flash button, mute button
- Volume Control
- Additional Features
- Noise reduction, PIN code, on-hook dialling
Phone Memory
- Phone Directory Capacity
- 25 names & numbers
Display
- Display Resolution
- 132 x 65 pixels
- Backlit
- Display Languages
- English, German, French, Italian, Norwegian, Portuguese, Spanish
- Connections
- Audio line out / RCA , Cellular phone connection headset jack / sub-mini-phone 2.5mm , 2 x microphone jack
- Cables Included
- Phone line cable - 2.1 m , Power cable - 6.4 m
- Included Accessories
- Power adapter
- VCCI Class B ITE, ICES-003, FCC Part 15 B, FCC Part 68
- Power adapter
Dimensions & Weight (Base)
- 31.1 cm
- 36.8 cm
- 6.4 cm
- 0.8 kg
- Limited warranty - 1 year
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
3TCC 041801 Condition: Damaged stock - Item is new but has packaging damage |
£52.92 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
