Brand
Poly Savi 8245 UC S8245-M C D200 USB-A Unlimited TT CONV MOC DECT UK / EURO / AUS / NZ
Quicklinx: G1CYWS00 Mfr#: 211204-02
Recommended Use: Phone, Phone, Computer
Connectivity: Wireless
£169.16 ex VAT
£202.99 inc VAT
The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 Series headsets for training or call resolution.
  • One headset for all your devices
    Today's enterprise and contact center professionals work across a range of devices - from PC to mobile to desk phone. The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 Series headsets for training or call resolution.
  • Connect and communicate more effectively
    The Savi 8200 Series headset system helps you achieve peak performance and productivity with a range of communication features. One-touch controls - such as call answer/end, volume up/down and mute - let you manage calls from any connected device within roaming range. Convenient voice prompts notify you of mute status, roaming range limit, and more.
Poly Savi 8245 UC, Unlimited Talk Time, Microsoft - headset
Headset - DECT - wireless
Recommended Use
Phone, computer
Headphones Form Factor
In-ear - convertible
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 118 dB
Impedance
32 Ohm
Active Noise Canceling
Microphone
Boom
Controls
Mute, volume, on/off, answer/end
Software Certification
Certified for Microsoft Teams
Series
8200 Series
115 g
Recommended Use
Phone, computer
Max Operating Distance
180 m
Audio Output
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Active Noise Cancelling Technology
SoundGuard DIGITAL
Frequency Response
20 - 20000 Hz
Sensitivity
118 dB
Impedance
32 Ohm
Diaphragm
32 mm
Microphone
Boom
Frequency Response
100 - 6800 Hz
Max Sound Pressure
112 dB
Remote Control
Controls
DECT USB dongle
Headset battery rechargeable - Lithium Ion
490 mAh
Run Time (Up To)
13 hour(s)
Standby Time
50 hours
Recharge Time
3 hour(s)
Recommended Use: Computer
Brand: Poly
