Poly ROVE 40 DECT IP Phone Handset
Quicklinx: GHYNWS00 Mfr#: 2200-86810-102
Keep the conversation going whenever, wherever – at work. Built for on-site employees the Poly Rove wireless IP phone solution delivers the sweet freedom to move and the flexibility to scale as you grow. Dropped phone? No problem. You're covered with ruggedized IP65, dust-tight, and water-resistant technology. Protection doesn't stop there. Built to stay cleaner for longer with Microban antimicrobial product protection. And guard your most critical conversations with DECT technology. We've got you covered. Built to last. Built to scale. Never miss a call. Communicate hands-free with a Poly headset using the built-in Bluetooth or 3.5mm connection.
  • Integrated microban antimicrobial protection
    Rest assured that your devices, enhanced with Microban antimicrobial product protection, stay cleaner, fresher and more durable for longer. Protection that lasts the life of the product, actively reducing the growth of bacteria 24 hours a day 7 days a week.
  • Guard your most critical conversations
    Conversations are safe and secure with DECT wireless security. And it doesn't stop there - maintain DECT encryption even when you add a base or repeater to your solution.
  • Ruggedized protection + pro-grade quality
    Built to withstand all that life throws at it. Drops. Dust. Water. The ruggedized handsets are drop proof up to 6.6 ft/2 m and IP65 dust-tight and water resistant. Your investment will go the distance.
Poly Rove 40 - cordless extension handset with caller ID - 3-way call capability
Cordless extension handset with caller ID
Total Number of Wireless Handsets
1
Cordless Phone Standard
DECT
Multiline Operation Capability
20-line operation
Speakerphone
Call Services
Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability, Enhanced Call Park
Display
LCD display - colour - Yes
Environmental Standards
ENERGY STAR Qualified
1-year warranty
1
Shipping Weight
379 g
Body Material
Ruggedised
Protection
Water-resistant, drop-resistant, IP65, dust-proof, Microban antimicrobial protection
Phone Features
DECT
Call Services
Caller ID Type
Caller ID
Dialer Location
Handset
20-line operation
Conference Call Capability
3-way
Speakerphone
Programmable Buttons Qty
4
Volume Control
Ring Tones
20
Indicators
Message waiting indicator
Additional Functions
Alarm, Intercom, redial, vibration alert, noise reduction system, call pickup, Do Not Disturb (DND), push to talk (PTT), OTA (Over the Air) upgrade, emergency key
IP Telephony
Voice Features
Acoustic echo cancellation (AEC)
Display
Display Location
Handset
Diagonal Size
2.4"
Display Resolution
240 x 320 pixels
Colour Depth
16-bit (65000 colours)
Backlit
Display Languages
Danish, Czech, Slovenian, German, French, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Serbian, UK English, US English
Headset jack / mini-phone 3.5mm
Hearing Aid Compatible
Belt clip, power adapter, charging cradle
ENERGY STAR Certified
1100 mAh
Rechargeable - Lithium Ion
Talk Time
Up to 1080 min
Standby Time
300 h
Dimensions & Weight (Handset)
171 g
Shipping Width
17.6 cm
Shipping Depth
16.3 cm
Shipping Height
4.4 cm
Shipping Weight
379 g
Limited warranty - 1 year
