The HP Inc. Poly headset extension cable is a versatile and essential accessory for anyone looking to enhance their audio experience. This cable features a Quick Disconnect option on both ends, allowing for effortless connection and disconnection. It's designed to maintain impeccable sound quality while extending the reach of your headset, ensuring that you can move freely without being tethered to your device. Whether you're in a busy office, at home, or in a gaming setup, the Poly extension cable offers the flexibility and performance needed to elevate your audio experience. Its compatibility with a broad range of headsets adds to its appeal, making it a must-have for audio enthusiasts and professionals alike.
Effortless connectivity
The HP Poly headset extension cable is designed to provide seamless audio experiences with its Quick Disconnect feature on both ends. This ensures users can easily connect and extend their headset reach without compromising sound quality. -
Versatile compatibility
With a universal Quick Disconnect interface, this extension cable is compatible with a wide range of headsets. This versatility ensures that users can enhance their audio setup regardless of the headset brand, making it a valuable addition to any audio system.
- Poly headset extension cable - 3 m
- Cable
- Headset extension cable
- Length
- 3 m
- Connector
- Quick Disconnect
- Connector (Second End)
- Quick Disconnect
- Cable Type
- Length
- 3 m
- Connector
- Quick Disconnect
- Quick Disconnect
- Shipping Width
- 31.115 cm
- Shipping Depth
- 38.735 cm
- Shipping Height
- 31.75 cm
- Shipping Weight
- 63.56 g
