Poly Poly Blackwire 3320 Stereo USB-C/A Adapter
Quicklinx: HQS4WS00 Mfr#: 8X219AA
Recommended Use: Computer, Portable electronics
Connectivity: Wired
45 In Stock
£30.52 ex VAT
£36.62 inc VAT
Built for style with a sleek design that focuses on comfort and reliability. Poly signature audio quality so you know you will sound great. And intuitive and simple features so every user can connect to their preferred device simply and easily.
  • High-quality audio
    Makes collaboration easy with Poly signature audio quality and reliability.
  • Wearing style
    Hi-fi stereo wearing style for those who want a richer, more immersive experience.
  • Flexible microphone boom
    With professional voice quality and a customized fit, this fully adjustable headset has 180-degree pivoting speakers and a flexible microphone boom.
  • Long-lasting comfort
    Supports long-wearing comfort with a plush, padded headband and pillow soft ear cushions.
  • Connectivity options
    Enhanced connectivity for your devices with a USB Type-C cord and tethered USB-A adapter.
  • Optimized for communications platforms
    An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
Poly Blackwire 3320 - headset - USB-C
Headset - wired - USB-C
Compatibility
Mac, Windows
Recommended Use
Computer, portable electronics
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 116 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Noise Cancelling
Controls
Answer/end, mute, volume
Software Certification
UC certified
Series
Blackwire 3300 series
Compatibility
Mac, Windows
131 g
Body Material
Artificial leather
Earpad Material
Foam
Recommended Use
Boom mic length 135mm, 280° rotatable microphone
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Sensitivity
116 dB
Impedance
32 Ohm
Max Sound Pressure
118 dB
Diaphragm
32 mm
In-Cord Volume Control
Dynamic EQ optimised
Microphone
Boom
Sensitivity
-38 dBV/Pascal
Frequency Response
100 - 10000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
USB (24 pin USB-C)
Software Included
Poly Lens
USB-C to USB-A adapter
Supported Host Device OS
Windows 10, macOS
UC certified
HQS4 Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 In Stock £13.18
HQS4 Poly - USB adapter - USB to 24 pin USB-C In Stock £13.30
HQS4 Poly - USB adapter - 24 pin USB-C to USB In Stock £13.04
Recommended Use: Portable electronics
Connectivity: Wired
Brand: Poly
