Built for style with a sleek design that focuses on comfort and reliability. Poly signature audio quality so you know you will sound great. And intuitive and simple features so every user can connect to their preferred device simply and easily.
High-quality audio
Makes collaboration easy with Poly signature audio quality and reliability. -
Wearing style
Hi-fi stereo wearing style for those who want a richer, more immersive experience. -
Flexible microphone boom
With professional voice quality and a customized fit, this fully adjustable headset has 180-degree pivoting speakers and a flexible microphone boom. -
Long-lasting comfort
Supports long-wearing comfort with a plush, padded headband and pillow soft ear cushions. -
Connectivity options
Enhanced connectivity for your devices with a USB Type-C cord and tethered USB-A adapter. -
Optimized for communications platforms
An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
- Poly Blackwire 3320 - headset - USB-C
- Product Type
- Headset - wired - USB-C
- Compatibility
- Mac, Windows
- Recommended Use
- Computer, portable electronics
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Sensitivity 116 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Answer/end, mute, volume
- Software Certification
- UC certified
- Product Type
- Series
- Blackwire 3300 series
- Compatibility
- Mac, Windows
- 131 g
- Black
- Body Material
- Artificial leather
- Earpad Material
- Foam
- Recommended Use
- Boom mic length 135mm, 280° rotatable microphone
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- Sensitivity
- 116 dB
- Impedance
- 32 Ohm
- Max Sound Pressure
- 118 dB
- Diaphragm
- 32 mm
- In-Cord Volume Control
- Dynamic EQ optimised
Microphone
- Boom
- Sensitivity
- -38 dBV/Pascal
- Frequency Response
- 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (24 pin USB-C)
- Software Included
- Poly Lens
- Included Accessories
- USB-C to USB-A adapter
- Supported Host Device OS
- Windows 10, macOS
- UC certified
Poly Headset Splitter - Y-type training cable for Poly Blackwire 5200 | In Stock | £12.76 |
Poly Quick Disconnect to Quick Disconnect Extension Cable - 3m | In Stock | £8.64 |
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £12.86 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
