Simply intuitive. Smart Sensor technology reacts when you put the headset on, letting you quickly take a call without a click. If you're already wearing it, Voyager Legend announces who's calling and waits for you to say "answer" or "ignore". Simply tap the voice command button and ask to check battery level, connection status, and more. With technology this nimble, Voyager Legend is the first truly intelligent Bluetooth headset.
Voyager Legend Bluetooth headset
Simply intuitive. Smart Sensor technology reacts when you put the headset on, letting you quickly take a call without a click. If you're already wearing it, Voyager Legend announces who's calling and waits for you to say "answer" or "ignore. " Simply tap the voice command button and ask to check battery level, connection status, and more. With technology this nimble, Voyager Legend is the first truly intelligent Bluetooth headset. -
Moisture protection
You can rely on the Voyager Legend to work as hard as you do, through rain, sweat and the inevitable coffee spill. Voyager Legend headsets are protected against sweat and moisture damage by P2i technology. The nano-coating is applied during the manufacturing process, resulting in invisible liquid repellent properties that also makes the headset more reliable, wherever your busy life takes you.
- Poly Voyager Legend - headset - with Charge Case
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Headphones Form Factor
- In-ear - over-the-ear mount - monaural
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Sound Output Mode
- Mono
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Controls
- Answer/end
- 2-year warranty
- Bundled with
- Charge Case
- Product Type
- 18 g
- Recommended Use
- Bundled with
- Charge Case
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP), Secure Simple Pairing (SSP)
- Sound Output Mode
- Mono
- Equaliser
- 20 bands
Microphone
- Boom
- Mono
Remote Control
- Controls
- Answer/end
- Included Accessories
- Ear tips kit
- Cable Details
- USB charge cable
- Power Device
- Power adapter - external
- Battery
- 1 x headset battery rechargeable - lithium polymer
- Included Qty
- 1
- Run Time (Up To)
- 7 hours
- Standby Time
- 264 hours
- Limited warranty - 2 years
