Keep the focus on your conversation, not background noise, with the sophisticated noise canceling and immersive stereo sound of the Plantronics Voyager Focus UC stereo Bluetooth headset.
                Work and entertainment that move with youOffering seamless connectivity to your PC or smartphone, and integration with UC applications, the Voyager Focus UC is ready to work how you do. With extensive wireless range, enjoy mobility while calls and music stay crystal clear, whether you're at your desk, in the conference room, or in the kitchen. Enjoy freedom with no loss of fidelity.
                You're not just on the call - you're in itMake it your business to hear and be heard. The groundbreaking active and passive noise canceling and immersive stereo of the Voyager Focus UC headset enable you to concentrate on your calls or your music without distractions. With precision-tuned mics and sophisticated muting opportunities, your callers can concentrate on you too. And when you need to pay attention to what's going on around you, just press the OpenMic button to focus on your surroundings.
                Worry-free muteControl your conversations with intuitive mute capabilities and built-in smart sensors. Easily mute/unmute with the touch of a button, or simply by taking the headset off and putting it back on. Music pauses automatically when a call comes in. If you try to talk while your mic is muted, the Dynamic Mute Alert will give you an audible reminder.
                Why whistle while you work when you can rockWhen it's time to crank up your music, the Voyager UC delivers rich bass, crisp highs, and natural midtones in amazing stereo. And it can take a cue -it pauses the music whenever you take the headset off, and resumes play when you put it back on. Plus, it can tell which way you're wearing it - thanks to the smart mic boom, the stereo, volume and track controls adjust automatically.
- Poly Voyager Focus UC B825 - headset - USB-A via Bluetooth adapter - UC Standard version
- Product Type
- Headset - Bluetooth - wireless - USB-A via Bluetooth adapter
- Recommended Use
- Portable electronics, computer
- Additional Functions
- DSP
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Sound Output Mode
- Stereo
- Active Noise Canceling
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Controls
- Volume
- Product Type
- DSP
- 155 g
- Recommended Use
- Max Operating Distance
- 30 m
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.1
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Sound Output Mode
- Stereo
Microphone
- Boom
- Mono
Remote Control
- Controls
- Volume
Wireless Link
- Transmission Range
- 45 m
- Connector Type
- USB
- Included Accessories
- Carrying case, charging stand, Bluetooth USB-A adapter
- Cable Details
- Charging cable
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 15 hour(s)
