Poly Plantronics Spare Telephone Inferface Cable, Savi and CS5xx .
Quicklinx: 7SGCWS00 Mfr#: 86009-01
The Plantronics 86009-01 Telephone Interface Cable is compatible with both the CS500 as well as the Savi Office range.
The 4-Pin module plugs into the handset or headset port of your desk phone. The RJ 45 end plugs into the back end of the wirless charging base, the telephone handset plugs into the middle of the cord.
Conductor:
Copper
Product Dimensions:
19.7 x 14 x 0.6 cm ; 3.2 Kg
Compatible with the following Plantronics Models:
  • Savi W710
  • Savi WO300
  • Savi WO350
  • Savi WO100
  • Savi WO200
  • Savi WG101
  • Savi WO101
  • Savi WO201
  • Savi W430
  • Savi W720
  • Savi W730
  • Savi W740
  • Savi W745
  • Savi W440
  • Dependable connectivity
    The Poly AV Cable Type provides a consistent and stable connection, allowing you to focus on your communication without interruptions.
  • Versatile compatibility
    This cable is compatible with numerous devices, making it easy to integrate into your existing audiovisual setup.
Poly phone line cable
Cable
Phone line cable
Cable Type
Phone line cable
