Poly Plantronics Savi 8220 UC Duo DECT Wireless Headset
Quicklinx: FR5HWS00 Mfr#: 209214-02
The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 Series headsets for training or call resolution.
  • One headset for all your devices
    Today's enterprise and contact center professionals work across a range of devices - from PC to mobile to desk phone. The Savi 8200 Series headset system makes call management effortless with three-way connectivity that lets you switch seamlessly between all of them. Conference two of your three devices to collaborate with colleagues or connect up to four Savi 8200 Series headsets for training or call resolution.
  • Connect and communicate more effectively
    The Savi 8200 Series headset system helps you achieve peak performance and productivity with a range of communication features. One-touch controls - such as call answer/end, volume up/down and mute - let you manage calls from any connected device within roaming range. Convenient voice prompts notify you of mute status, roaming range limit, and more.
Poly Savi 8220 Microsoft - wireless headset system
Wireless headset system - DECT 6.0 - wireless
Headphones Form Factor
On-ear
Wireless
Wireless Technology
DECT 6.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 118 dB
Impedance
32 ohm
Active Noise Canceling
Microphone
Boom
Controls
Volume, power on/off, answer/end, ANC on/off
Software Certification
Certified for Microsoft Teams
Series
UC Series
160 g
Max Operating Distance
180 m
Audio Output
On-ear
Wireless
Wireless Technology
DECT 6.0
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
118 dB
Impedance
32 ohm
Diaphragm
32 mm
Microphone
Boom
Headset microphone
Frequency Response
100 - 6800 Hz
Max Sound Pressure
112 dB
Remote Control
Controls
DECT USB dongle
Headset battery rechargeable - Lithium Ion
700 mAh
Run Time (Up To)
13 hour(s)
Recharge Time
3 hour(s)
