Designed for Xbox One, the RIG 500HX headset delivers performance audio you can count on with durable, lightweight comfort for competitive challenges.
FOCUS WINS
The durable yet lightweight frame lets you configure components for endurance or focus. The included isolating ear cups immerse you in the game, blocking out distracting background noise.
CONFIGURE TO WIN
RIG 500 is designed to let you change out components to match your needs. Opt for immersive, isolating cups to game in peace or choose the open, vented cups to keep your cool during long sessions. The flexible headset frame can be swapped out for translucent or camo color options.
PERFORMANCE AUDIO
Audio fidelity that gives you an edge. Dynamic, 40 mm drivers are matched with low-frequency resonators to boost the bass response without destroying crucial mids and highs. The noise-cancelling boom mic flips up to mute, making it perfect for solo campaigns.
Performance audio
Audio fidelity that gives you an edge. Dynamic, 40 mm drivers are matched with low-frequency resonators to boost the bass response without destroying crucial mids and highs. The noise-canceling boom mic flips up to mute, making it perfect for solo campaigns. -
Focus wins
The durable yet lightweight frame lets you configure components for endurance or focus. -
Configure to win
- RIG 500HX - headset
- Product Type
- Headset - wired
- Recommended Use
- Game console
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 111 dB
- Impedance
- 32 Ohm
- Max Input Power
- 40 mW
- Microphone
- Boom
- Controls
- Microphone on/mute
- Designed For
- Xbox One
- Product Type
- Headset - wired
- Earpad Material
- Memory foam
- Recommended Use
- Game console
Audio Output
- Full size
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Max Input Power
- 40 mW
- Sensitivity
- 111 dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
- Adjustable Headband
Microphone
- Boom
- Sensitivity
- -45 dBV/Pascal
- 100 - 10000 Hz
- Signal-To-Noise Ratio
- 42 dB
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
- Cable Details
- Headset cable
- Designed For
- Xbox One
