Brand
Poly Plantronics PLA U10 Cable
Quicklinx: 854GWS00 Mfr#: 38222-01
3 in stock
£14.08 ex VAT
£16.89 inc VAT
Standard delivery Delivered within 3-5 working days
Plantronics offers products for the computer and mobile market segments, specializing in telephone products, such as amplified telephone headsets, telephones for hearing-impaired users and noise-canceling headsets, handsets for use in high-noise environments and value packs. As the world's leading designer, manufacturer and marketer of lightweight communications headset products, Plantronics produces a great deal of accessories for its versatile headsets.
Poly headset cable
Cable
Headset cable
DuoPro
Cable Type
Headset cable
Poly - Plantronics DuoPro
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 854G 043085
Condition: Customer return - item has been used and shows signs of use. Not in original packaging.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £1.51
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Poly
Stock Status: In stock
Stock Status: Used Stock
