Poly Plantronics HIC-10 Adaptor Cable (replaces HIC-1 Cable / was 7SJD)
Quicklinx: BYDKWS00 Mfr#: 49323-46
With Quick Disconnect, for connecting corded headsets directly to Avaya phones. The Quick Disconnect (QD) capability allows the headset to detach without losing the call.
  • Efficient connector design
    The quick disconnect male connector enables quick and easy connections to the headset, perfect for various communication settings.
  • Versatile compatibility
    This adapter cable works with multiple Avaya models, ensuring it meets the needs of users with different phone types.
Poly HIC Adapter Cable - headset cable
Cable
Headset cable
Connector
Quick Disconnect - male
Avaya 2410, 2420, 4406, 4406D+, 4412, 4412D+, 4424, 4424D+, 4610SW, 4620, 4620SW, 4621SW, 5410, 5420, 5610, 5620, 6416D+M, 6424D+M; MERLIN MAGIX 4424D+, 4424LD+
Cable Type
Headset cable
Recommended Use
IP phone
Connector
Avaya 2410, 2420, 4406, 4406D+, 4412, 4412D+, 4424, 4424D+, 4610SW, 4620, 4620SW, 4621SW, 5410, 5420, 5610, 5620, 6416D+M, 6424D+M , Avaya MERLIN MAGIX 4424D+, 4424LD+
