With Quick Disconnect, for connecting corded headsets directly to Avaya phones. The Quick Disconnect (QD) capability allows the headset to detach without losing the call.
Efficient connector design
The quick disconnect male connector enables quick and easy connections to the headset, perfect for various communication settings. -
Versatile compatibility
This adapter cable works with multiple Avaya models, ensuring it meets the needs of users with different phone types.
- Poly HIC Adapter Cable - headset cable
- Cable
- Headset cable
- Connector
- Quick Disconnect - male
- Designed For
- Avaya 2410, 2420, 4406, 4406D+, 4412, 4412D+, 4424, 4424D+, 4610SW, 4620, 4620SW, 4621SW, 5410, 5420, 5610, 5620, 6416D+M, 6424D+M; MERLIN MAGIX 4424D+, 4424LD+
- Cable Type
- Headset cable
- Recommended Use
- IP phone
- Connector
- Designed For
- Avaya 2410, 2420, 4406, 4406D+, 4412, 4412D+, 4424, 4424D+, 4610SW, 4620, 4620SW, 4621SW, 5410, 5420, 5610, 5620, 6416D+M, 6424D+M , Avaya MERLIN MAGIX 4424D+, 4424LD+
