Poly Plantronics EncorePro HW715 USB Noise Cancelling (Mono)
Quicklinx: CSN9WS00 Mfr#: 203476-01
The all-day comfort, reliability, and durability the EncorePro Family is known for, with the addition of built-in call control. The EncorePro 700 USB Series is ready for every call because every call matters.
Clarity, Comfort, Control
The EncorePro 700 USB Series is a fully integrated audio solution that enables users to focus on every conversation with all-day comfort, built-in call control, advanced audio processing and an enhanced noise canceling microphone. The result? An experience that makes every conversation sound natural, enabling the user to focus on what matters most - the conversation.
Luxurious Comfort, Distinctive Design
The top-of-the-line series, featuring exceptional audio quality. Made from high-grade nylon composite materials, with soft leatherette ear cushions, the EncorePro 700 USB Series provides the user with an ultra-lightweight fit for all-day comfort. The unique, extendable boom ensures precise positioning for optimal noise cancellation and voice clarity, staying clear of the user's peripheral vision so that they can focus on other tasks at hand.
  • Clarity, comfort, control
  • Luxurious comfort, distinctive design
Poly EncorePro HW715 - headset
Headset - wired - USB
Compatibility
Mac, Windows
Recommended Use
Phone, computer
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Mute, volume, answer/end
Works With Chromebook
Compatibility
Mac, Windows
Recommended Use
Phone, computer
Audio Output
On-ear
Wired
Sound Output Mode
Mono
Adjustable Headband
Microphone
Boom
Mono
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Cable Details
Headset cable
