Poly Plantronics CS540 Wireless Handset with HL-10 Handset Lifter
Quicklinx: 7R9LWS00 Mfr#: 84693-12#SP
Recommended Use: Phone, Phone
Connectivity: Wireless
Earcover : Monaural
£141.81 ex VAT
£170.17 inc VAT
Plantronics legendary CS family is setting a new wireless standard with the CS500 series. The CS540 features a new headset design, streamlined base and improved performance, all with the same dependability for wireless productivity that has made the CS series a best seller. The CS540 features the lightest headset in the industry weighting only 21 grams, gives you up to 350 feet of range to roam your office, and a battery made to last all day giving you 7 hours of talk time.
Superior comfort and call management * Gain mobility - multitask hands-free up to 120 metres * Audio controls volume/mute at your fingertips * Conference in up to three additional headsets for enhanced collaboration * Offers you a choice of three comfort-tested wearing options to match your personal style * Use with Electronic Hookswitch Cable or Handset Lifter to remotely answer/end calls (sold separately)
Outstanding audio quality * DECT technology provides better audio; eliminates interference from Wi-Fi networks * Advanced wideband audio using CAT-iq technology for high definition voice quality * Noise-canceling microphone reduces backgroundnoise interruptions, ensuring great audio quality and easing listener fatigue * Enhanced Digital Signal Processing (DSP) provides more natural sounding voice
Poly CS 540 - headset - with Plantronics HL10
Headset - DECT - wireless
Recommended Use
Phone
Headphones Form Factor
Convertible
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Microphone
Boom
Controls
Answer/end
Bundled with
Plantronics HL10 Handset Lifter
21 g
Recommended Use
Phone
Max Operating Distance
107 m
Bundled with
Audio Output
Convertible
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Microphone
Boom
Remote Control
Controls
Answer/end
Wireless Link
Transmission Range
107 m
Handset lifter
Power adapter - external
Headset battery rechargeable
Run Time (Up To)
7 hour(s)
7R9L Poly Plantronics HL10 lifter for SAVI Office Range In Stock £24.22
7R9L Poly Plantronics APS-11 Electronic Hookswitch Cable In Stock £30.05
7R9L Poly Plantronics APN-91 NEC EHS In Stock £18.99
7R9L Poly Plantronics APC-45 EHS (Electronic Hook Switch) for Cisco In Stock £24.21
7R9L Poly Plantronics APU-72 Electronic Hook Switch In Stock £22.28
Resources
The following resources are available for the Poly Plantronics CS540 Wireless Handset with HL-10 Handset Lifter
Earcover : Monaural
Brand: Poly
