The no cord, no fuss UC speakerphone. The perfect tool for impromptu conference calls, the Plantronics Calisto 620 is a portable wireless UC speakerphone that instantly transforms your laptop or smartphone into a high-quality conferencing device. Small and lightweight, the Calisto 620 provides professional-sounding audio and wireless connectivity, wherever you touch down.
Dual connectivity, enhanced portability
The perfectly portable, wireless speakerphone that takes UC on the road. It's designed to simplify call management with an easy interface for answer/end, mute and volume on your laptop or smart phone, and it comes with a Bluetooth mini USB adapter for always-ready PC connectivity. With its own high-quality travel case, the small, lightweight speakerphone is the right size for your laptop bag or carry-on, without cords or fuss. -
Superior audio quality
Offering unmatched audio clarity, the Calisto 620 features 360-degree full duplex audio and Bi-directional microphones that activate in the direction of the speaker's voice so callers hear you - not your background. PC wideband audio and Digital Signal Processing (DSP) reduce drop-outs and echo with Acoustic Echo Canceller. Integrated A2DP lets you listen to streaming media from your mobile device, including your favorite songs, podcasts and more.
- Poly Calisto P620-M - speakerphone
- Product Type
- Speakerphone - Bluetooth - wireless
- Recommended Use
- Portable electronics, computer
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 2.1 EDR
- Microphone
- Built-in
- Microphone Operation Mode
- Bi-directional
- Controls
- Mute, volume, answer/end
- 2-year warranty
- Product Type
- 11 cm
- 11 cm
- 3.2 cm
- Recommended Use
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 2.1 EDR
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
Microphone
- Bi-directional
- Directivity Angle
- 360°
Remote Control
- Controls
- Connector Type
- Bluetooth , USB (4 PIN USB Type A)
- Included Accessories
- Carrying case
- Power Device
- Power adapter
- Battery
- Speaker phone battery rechargeable
- Run Time (Up To)
- 7 hour(s)
- Standby Time
- 120 hours
- Limited warranty - 2 years
