Poly Plantronics Calisto 5200 USB-A & 3.5mm Speakerphone
Quicklinx: FMFNWS00 Mfr#: 210902-01
Compact hands-free alternative to the headset, great for conference calls, collaboration or web conferencing.
  • Clear audio performance
    The Poly Calisto 5200 features an omnidirectional microphone that captures sound from every direction, ensuring crystal-clear communication in meetings and calls.
  • Noise reduction capability
    With integrated noise canceling technology, this speakerphone delivers focused audio quality by reducing unwanted background sounds that can interfere with conversations.
  • Versatile connectivity options
    The device offers multiple connection types including a 3.5 mm jack and USB, making it compatible with a range of devices from laptops to mobile phones for easy use.
  • Intuitive controls
    The Poly Calisto 5200 includes straightforward controls for muting, volume management, and call handling, making it user-friendly for all audio needs.
Poly Calisto 5200 - speakerphone
Speakerphone - wired - USB, 3.5 mm jack
Recommended Use
Portable electronics, computer, conference - communication
Wired
Microphone Operation Mode
Omni-directional
Microphone Noise Cancelling
Controls
Mute, volume control, answer/end
Recommended Use
Audio Output
Wired
Microphone
Omni-directional
Directivity Angle
360°
Noise Cancelling
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A) , Speakerphone (mini-phone 3.5mm)
Carrying case
Cable Details
USB cable , Speakerphone cable
