The Blackwire 5200 Series fits your busy workday. Easy to use, USB and 3.5 mm connectivity lets you work on a variety of devices. And it's so comfortable, you'll be able to wear it all day. The Blackwire 5200 Series-connect, work, seamlessly.
All-day comfort and universal connectivity
When you need to wear a headset all day, the Blackwire 5200 Series has you covered in the utmost of comfort. Ergonomically designed, it's comfortable enough to wear all day, on your longest calls. -
Astounding audio
Noise-canceling mic with flexible boom, microphone meets Near Talker specifications. -
Outstanding audio quality for better productivity
Today's workplace can be noisy and filled with distractions. With the Blackwire 5200 Series, you'll be able to hear and be heard more clearly, enjoy conversation privacy and be more productive. That's because soft, conforming ear cushions provide passive noise canceling, while a precisely tuned microphone masks nearby conversations. -
A headset that works the way you do
Adjust the headset to fit the way you work. Dedicated, customizable mute settings allow you to take calls confidently, ensuring you're always heard. Set the language for voice alerts, and you're in even greater control of your conversation.
- Poly Blackwire 5220 - headset
- Product Type
- Headset - wired - USB, 3.5 mm jack
- Recommended Use
- Computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Controls
- Mute, volume, answer/end
- Product Type
- Series
- 5200 Series
- Dimensions & Weight Details
- 164.2 g
- Headband Material
- Cushioned metal
- Earpad Material
- Leatherette
- Recommended Use
- Protection
- Hearing protection
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- In-Cord Volume Control
- SoundGuard Technology, voice alerts
Microphone
- Boom
- 100 - 8000 Hz
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Carrying case
- Cable Details
- Headset cable
